SLOW 7M'S Build with lots of custom parts.
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
looks great!
a question for you, i have a ffim too, but one thing im not clear on is the vacuum fittings for them. you have one leading to a vacuum manifold, and then to the brake booster. do you not need some sort of check valve so prevent everything from seeing boost when the intake manifold is pressurized?
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
Its a 12 AN i used a 12 An to 3/4 NTP and made a little steel sleave that you locktite and just press right into the block after you pull out the factory bung.
empera;958150 said:
valve cover to block, looks like a -10AN maybe bigger.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
xXSupramanXx;958395 said:
Your doing a great job!! how much power are u goin for??
Before or after i spray the shit out of it?
Enraged
The vac manifold you want to see boost. But i reused the stock check valve before the brake booster so it wont see boost.
Sil
Evil Empire
Jan 13, 2008
340
Milwaukee/Chicago
Had free time so I went through this build thread, needless to say looks awesome. Can't wait to see this thing in its final point somewhere along the line. And thanks for the MC brace, got it put on just waiting to finish the rest of my brakes to try it!
RWHP
Going for 1JZ
Jan 14, 2008
126
Ostersund
Where can i find these?
The only negative thing about that is that you wont get vacuum in the crankcase if you dont use a vacuum pump, but that you already know i think?
wesbeech
Feb 26, 2006
1,022
Akron Ohio
They are from summit racimg with modified earls weld on bungs.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Tun_x;964793 said:
mmmmmmmmmmmm. spraaaaaaaayyy
Wait till i get the second bottle. That reminds me i need to call them and see what the bigest spray is i can run on that system.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
HMM this can only mean one thing.
Time to start the engine work yeah :naughty:
Welli got some stands fabed up for the car it will make some jobs so much easter. And its nice cuz the car is at ride height but a little over a foot off the ground.
