I made a video of my exhaust and my idle sounds a little rough. What do you guys think? Here's the video:
http://www.youtube.com/watch?v=0VsYkbt6XBk
jdub;1351884 said:That doesn't sound bad actually. What plugs and wires are you using?
nick88;1351888 said:check for lose plug wires on the plug or coilpack and learn about your car and how it works before posting stupid questions
jdub;1389307 said:Stock gap I assume? What's the idle RPM?
Did you check for ECU codes?
Check timing as you said...be sure to reference the TSRM for how. Check for vac leaks and any cracks in the intake accordion hose.
CajunKenny;1389323 said:He didn't post any stupid questions. He asked about his idle and even posted up a nice vid with good audio.
No offense; but, ease up.
hvyman;1389748 said:650 is the spec for idleing rpm. if it drops below that the engine will run ruff cause its harder to keep the engine going with such low rpm. whats the engine sound like?
hvyman;1389762 said:get a vid of the engine. to check codes all you do is go to the diag box(the lil gray one next the the fuse box under hood) and jump te1 and e1 with a paper clip. you could have a vac leak, might need to clean out the isc, tps. check your codes
Alec;1389766 said:But I have no check engine lights. What do I do once I jump te1 and e1?
