AbsoluteSpeed;1924199 said:
Looks awesome Dustin!
Can you post a picture of the mounting bracket?
The brackets are really just aluminum strap...
Alright so Ive been playing with vacuum forming to create a closed assembly out of the aiming bowl. I havent siliconed anything because the clear lenses come in today. First I vacuum form the rear piece. Then I trim it out of the plastic. Now the projector rear pokes through the hole so as I apply the rear piece I heat the plastic so that it forms around the projector housing. With the brackets and the rear support the projector sits securely.
Then using electrical tape I made a screen for the front portion of the vacuum forming. Then I trimmed it and painted it.
Once these are closed then I will place a vacuum formed wind screen on the black trim that will protect the projector glass.
