honestabe;1276278 said:
I think your idea is brilliant making a 1 piece speedo cable. I'm pretty sure the rubber grommet is there to prevent rubbing that can eat through the speedo cable and cause it to break. Any pics of your speedo cable and how did you make it?
Adam
Sorry Adam
No pictures I didn't have my camera with me ...
First I dissambled the dash pull the gauge panel out and disconnected the cable.
After that i opened the front and cut this small rubber grommet on the hole ,removed it , so the cable had just enough place to pull it out -it had a green hard plastic connector at the end ,it just came out very slowly you have to play with it- ...and there is absolutely no place so you need to have a small hand otherwise don't even start it hehehe:biglaugh:
The cable goes just behind the engine if you face the car , to the left and after it goes under beside the engine ,behind the turbo
So I went under the car and disconnected the other end of the cable from the transmission.
I got a 1 meter long cable - from the parts a 40 cm long and a 60 cm long, they were attached to each other with a joint(hope i say it the right way- i have been living in the US / Florida for a year but it was in 1995-96 and from that point my english is getting worse...)
So I had this cable , i measured it and made a one piece same length and connected this green hard plastic connector on the speedo end
After I had it ready I put it through the firewall hole , connected the green end to the speedometer's spiral-it was very hard no place and really couldn't see anything
The fifth try was successfull :biglaugh:
After that i put the inner cable/wire we call it bowden into it and tested it
If you grab the inner line and and move it round / route it inside the needle should move a little-that's how you can test it
Important that the inner line should be long enough to reach the spiral...
After this I went under the car and reconnect the other end to the transmission/here make sure that the heat covers are back on the cable cause there can be really hot-protect the cable
Done works nice and smooth
