03bamaGT;1304205 said:I will most likely be at the meet...hehe.
suprahero;1304145 said:Kevin G. Do you go to Jeff St.? I saw a red MKIV while I was doing some work over there. This car was turning left off of 75 to go up the road to Jeff St. It's only the second MKIV I've ever seen going down the road.
As for your choices, I'd definately go with a turbo set up over the six speed. You won't regret it.
suprahero;1304579 said:My five speed has lasted for over three years on stock tranny and I've been making over 450 rwhp for that ammount of time. I'm currently making 552rwhp and it's working flawlessly.
ForcedTorque;1308777 said:How about pictures of my motor that I just pulled with everything in place....out of the car where you can see it. I'm not sure when I can post them, but sometime over the weekend. It'd probably be tomorrow or Sunday.
jrfn354;1309171 said:My problem at the moment is hoses. I'm not sure which ones connect to the accordian hose.
ForcedTorque;1309195 said:I'm in the Mobile area. The accordian is pretty simple. The AFM goes on one end, with the connector facing inward toward the block. Then it connects to the turbo. Then, you have the three PVC hoses, and they should be pre-formed. One comes off the BOV and goes to one of the forward holes. The other front one goes to the PVC pipe in front of the 3000 pipe. The one furthest from the turbo connects to the PVC pipe closer to the AFM. Then there is a little vacuuum tube on the bottom. A vacuum hose runs fron there to a little fitting on the back of the power steering pump below. Hook it on the post that is closest to the fender.
jrfn354;1309628 said:Unfortunately, the engine I bought was CUT out of a car. The stock blowoff valve and PCV hoses are gone completely.
