show us your swap
nathaninwa
377
Aberdeen, WA
Well, prelim numbers are in. I need to head back for a real run. Since the start of the motor its been running goofy and would not idle less than a 13.0. Well, number 4 injector was taking a shite, and became evident on the third dyno pull when it went full open.
So with a map thats a bit rich, (low 11's) and low timing, the car made 460/422 on 91 pump at 14.5psi. I imagine once the injectors are right! thatll pick some and since were just getting into the turbos good part, power will increase alot from here.
te72
Classifieds Moderator
6,611
7
WHYoming
...all in an old, sedate looking Volvo. You sir, might be my hero around here. Would be better if it were a wagon (just because), but I'll settle for the 940. :)
nathaninwa
377
Aberdeen, WA
I like the sedan a little more than the wagons in the 7/9 series, but really like the 240 wagons, its just a total sleeper, the only give away are the Willwood brakes!
CRsupraiii
195
Cedar Rapids, IA
First start last night, first drive last night!!! Sounds like a demon. :D
