Hey guys I noticed when I put my turn signal on, my lights dim slightly each time the signal blinks. The voltmeter drops up and down about half a volt when the right blinker is on, and an entire volt when I have the left one on. If I put my emergency lights on, via the switch, the volts are steady, and don't drop at all. I also noticed when I brake, my lights dim just slightly and the volts drop about 1/4 volt. Same with my windows, if I lower or raise them together, they're really sluggish, and my volt meter drops about half a volt. Once they're fully closed or open, the lights brighten up again.
The alternator is brand new, so I doubt it's that, considering it did it before I had it replaced. I'm thinking maybe a bad ground (or going bad), or maybe a short somewhere..? Possibly both?
What do you guys think?
