annoyingrob said:
I had the plastic bushings that surround the ball of the shifter crack, as well as the shaft separating into two pieces.
If this is the S3 V2 shifter....
The internal bushing (one) is from a BMW 3/5 series. Chosen for easier future
replacement. BMW's usually need these replaced at 30-50K.
I've seen them in older BMW's where they have a split or missing one of the "teeth",
though the design is quite smart as it still holds the shifter fulcurm sphere in place.
As for the shaft seperating into two pieces, the V2 shifter is a two piece design.
This to allow some height adjustment. Most do not change it,
as it is set to the shortest position when assembled.
I'm assuming this is what you are referring too.
One generic condition is that any short shifter will amplify problems with a worn transmission.
The S3 shifter, C's, etc. I've seen this first hand with a R154 that the upper engagement rod was plain loose.
This side-to-side play, combined with likely other internal wear is going to create shock against
the complete shift engagement components.
For reference, this is not a SupraSport shifter. They are one of a few vendors that sell the S3 shifter.
