CajunKenny;1557415 said:I apologize everyone. Due to wastegate problems, the dyno numbers will be slightly delayed.
But keep those guesses coming!![]()
The pivot length connected to the gate or the rod leading to the pivot? If the latter, that rod will translate motion/velocity the same regardless of it's length.CajunKenny;1557637 said:^I shortened the wastegate actuator rod.
kneedragger85;1557809 said:The pivot length connected to the gate or the rod leading to the pivot? If the latter, that rod will translate motion/velocity the same regardless of it's length.
Kevin;1557829 said:so whens the next dyno date?
Nosechunks;1557842 said:
IJ.;1559347 said:Beware of creep on the top end now Kenny, make sure you tell the dyno operator it's a potential issue so he can back out of it if needed.
tekdeus;1559384 said:True, especially on pump gas. Isn't 16-17psi pushing it already?
