Sheedy Built Supra
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
This is the most recent dyno sheet from supra nationals at PSI
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Pulled the engine out today. I may need to purchase a new header that sits the turbo forward more
Since I have more brake lines with abs I think my downpipe will hit. Anyone have any input on a t4 or t3 header that sits the turbo between cylinders 3 and 4?
Harness looks to be in way better condition than my white cars harness.
7mgte also for sale!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Started working on the cluster. I'm thinking I'll have aem oil pressure and tru boost in the cluster itself, then the aem wideband right on the steering column.
Want to look less like I have a turbo with the 3 pod pillar. A lot of my friends couldn't tell I was boosted except for the pillar. Anyway here's some pictures.. Not completed of course
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
http://a
tapatIalk.image71e0b1e1d4c2fef3a7616.jpgthe. not shack.comcompresson be /v2/14/10/19/1405dc722af[URL]a tapatalkr. [/URL]71e0b1e1d4c2fef3a7616.jpLot Ltd From 71e0l[IMG]g [/IMG][. For erg/QUOTE]Zag
. Quite
sheedy126;2024852 said:
Change of plans. My motor is going in the red one.
1986.5supra_kid;2024884 said:
Do you have a dyno sheet for your setup?
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
New header showed up from the mail man today. Looks much better than the old one and sits the turbo between runners 3-4 and not 4-5. Lots of room for a downpipe now!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
With the old setup I had to hammer the firewall in about an inch or so. With the new shell it has extra lines for abs so I can't really do that now. The flanges will need surfaced since they are a little out
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Power steering resivor showed up. Going to run -6 and -10 black nylon braided line with russel fittings. New build is coming along nicely just need to find time to get everything installed!
Wastegate disassembly, clean/lube annd reassembly
