Scotty's Toyota Supra MKIII
limequat
Dissident
Detroit
scotty;1434081 said:
Don't understand the question?
Are you asking if it's worth it to do a cat-back as opposed to a full exhaust?
I'd say do neither and put the money towards an engine as you'd originally planned.
scotty
476
Norway
scottnicholas.net
Sorry, I see it's a bit of a silly question now. What I ment was do I need a catalytic converter? And a full exhaust, is that basically just a cat-back, test-pipe and a downpipe?
About the engine plans.. that's not going to happen in a few years, as I'm a student now, and I don't have time to do it. The car is going to be a daily runner aswell.
A exhaust I can use on both NA and Turbo if it's 3". So can just aswell buy that now.
limequat
Dissident
Detroit
Do you need a cat? That's between you and your god.
By full exhaust, I meant everything from the manifold back.
Good point on reusing the cat-back exhaust. Sounds like a good plan to me.
BTW, I built myself a 3" cat back for about $100 in materials + muffler. The muffler was almost $200. Looking back, I'd probably just buy a used setup.
scotty
476
Norway
scottnicholas.net
Yer.. looking on ebay and the sales category quite often for used exhausts..
I'm thinking of just buying a Pacesetter 2.5".. it's only $220-280 ... and the dollar is really cheap now aswell.
Just paint it with heat resistant paint, to don't get it to rust, and then cut of the twin tips(which are like 1-1.5" inside?) and replace with some bigger twin tips.
eraezer
851
9
Stockholm, Sweden
Yes, a full exhaust goes all the way from the turbo or manifold.
You only need a cat if your law say's you do.
I will build a 3" without a cat and just install a stock cat when it's time for inspection.
