San antonio
san supra
833
san antonio
Suprapowaz!(2);1532578 said:
http://paintshop101.com/ 5704 Kenwick Street. Near Bandera & Loop 410.
They're Mopar guys. They do some serious restorations. Expect to spend some money... anywhere you go for that matter. Did you say it's a 1974 model? Who's is it?
this guy chris i know
the car is pretty quick
it smells like 74
he has 2 in his garage
san supra
833
san antonio
S.A. supra;1532772 said:
David How did that it go with the engine?
slow because i didnt want to work on it.
the front and oil pan are off but i still need to pull the head.
the rtv got behind the t-case and acted as a wedge so it wouldn't seal
rufus any other shops?
he told me last time he went there there was a year long waiting list
he said he would check it out again
Suprapowaz!(2)
2,870
San Antonio, Tx.
san supra
833
san antonio
Suprapowaz!(2);1533322 said:
As far as custom restoration type shops go not really. There's other good reputable shops out there like Dale's on Broadway http://maps.google.com/maps/place?h...ear=san+antonio,+tx.&cid=13890475207027396960. I've heard good things come out of Jack's Paint Place http://www.jackspaintplace.com/press.htm.
Atlas body and paint on Carson near New Braunfels http://www.atlasbodyshop.com/.
I'm sure any one of those would do the work right away.
thanks for the info
i will pass it on
S.A. supra
2,405
Buda, Texas
Nope. I've had my eye on this supra for a couple of years and now its for sell. it's a 87 gay blue looks very nice from the out side. it's supost to be clean on the inside. and 55000 original miles. i'd take it but i already have my hands full.
nicole43105
62
san antonio, tx
Well update on the car, gotta pull the engine the manifold studs are backing themselves out... so they need rethreaded and the valve cover gaskets are bad so im going to rebuild the whole thing proll starting next month... any suggestion on where to get the head or the block machined
nicole43105
62
san antonio, tx
just keep spinning when you tighten them down but the studs arent stripped, so im going to retap the wholes in the block and rebuild the engine with some upgrades while i got it out of the car
Suprapowaz!(2)
2,870
San Antonio, Tx.
If they keep spinning then the bolt holes on the head are stripped. You should do a compression test before you decide to do a rebuild. If the compression is good across the boad then why bother with a rebuild? If the numbers are out of whack then sure, rebuild it. With the money you save on a rebuild you can upgrade something. Just retap and helicoil the head, valve job while it's out, adjust valve lash, new valve stem seals and call it a day.
san supra
833
san antonio
yep
