If y'all need or want anything let me know. I'm gonna have a guy come by and take everything for scrap.
Suprapowaz!(2);1938806 said:If they do have all steel lock nuts let me know. I'll go get some.
Suprapowaz!(2);1938806 said:Did you ever tune out area around 2000rpm? You did say you have 12v mod done right?
Do you happen to have any of these:S.A. supra;1938852 said:If y'all need or want anything let me know. I'm gonna have a guy come by and take everything for scrap.
1988ma70supra;1939502 said:I didn't get a chance to go, a bunch of drama has been going on with one of my sisters. To make a long story short she was going to get married by the church next month and now it seems to be called off and depending on what happened i might have to make a trip to Corpus to go whoop his ass :aigo: I should have enough time tomorrow so ill probably be stopping by then. If i find the correct size ill go ahead and get them for you and meet you up whenever you have some free time. Either way ill keep you posted on that.
I threw all of that stuff already.
I haven't done the 12V mod yet but i still dont think the fuel pressure is the problem as it doesnt drop or fluctuate when I'm nearing or passing that rpm. I did notice the other day though that one of the wires from the O2 sensor connector is literally hanging by a thread on the far inner portion of the connector inside the individual wire weather seal. (I can't believe i missed it when i changed the O2 sensor after doing the heli coil on the exhaust studs a couple of months ago) Its not on the O2 sensor side but on the engine harness so I'm hoping that maybe this is the culprit although i doubt it since it started to act up after doing the AFPR so :dunno:.........either way i need to fix it. The connector is pretty dried out and crispy so I think ill have to find a good connector at a junkyard that i can solder in or just find a different style 3 pin connector and solder that one instead. I would prefer the original since i just replaced the O2 sensor and wouldnt want to hack it up everytime i change the O2 sensor.
The healiner for a targa part that holds the dome lights; the dome lights too if you have them and the glove box
The vent grill thing
A good condition drivers side door panel & a retractable hatch cover, all in blue
Suprapowaz!(2);1939613 said:Thanks David. I'm going to try some of the other nut and bolt specialty stores. If I can't find them there then I'll get them from dealership. I'm not in a hurry.
I have another issue on hand. My idle isn't steady, it bogs here and there and dies from time to time. I didn't notice this before, but after I raised my fuel pressure up pretty high it started doing that. I dropped my fuel pressure back down to 44psi vacuum disconnected, and it still does it.
I'm going to go back to the lex afm setup to see if my problem goes away. I want to see if it's my settings on the map ecu that's making the idle act erratic. I'll go from there. I don't want to make any assumptions at this point. I do, however, need bigger injectors to run higher boost.
NicMK3;1940709 said:What's up guys been awhile so I finished the build top and bottom new turbo new head block all new internals, and my dad blew the motor before I even had 100 miles on it. So now I'm wondering if anyone knows where I can buy a hole new motor completely built cause I don't want to have to deal with my mechanic and the time it will take. I was told about ordering from Japan. Any references?
Nic
