rod knock
turbo2
59
hawaii
is it hard to change rod and main baearings while the motor is still in the car?:1zhelp: i got another motor but its a 90-91 ish and i would need another harness
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Someone in that thread mentioned that the mkii had enough room to pull the pan by simply unbolting the motor mounts and jacking up the tranny. I'm not sure that'd work on a mkiii. Worth a shot i suppose. Jack it up and look at it for 5 mins and see if there is any possible way you'd have enough clearance.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
I would hate to have to tackle this job with the motor still in the car, but I read that thread on how to do it and it seems possible, just maybe takes a little more patience.
turbo2
59
hawaii
ok thaat takes kare of that prob. i just installed a spec stage 3 but it still feels like stock. anybody got anwsers for that?
staticpat
Supra Chair!
Birmingham, AL
Wow I am famous.
It can't hurt to try and jack the motor hella up like the mkii people do. The tranny and everything is really fat so I don't know how much space you could get.
Honestly if you have a good engine I'd just get the harness and swap it in. Are you considering taking the rotating assembly out of one engine and putting it in the other? These aren't chevy's, our engines have very tight specs and I personally wouldn't try it,
SMP142
BOHICA
Jan 5, 2006
367
Tacoma, WA.
turbo2 said:
o and my spec stage 3 clutch feels like stock
do you mean it feels like stock clutch in the pedal? or it still slips like the stock clutch did? (assuming your stock clutch slipped :biglaugh: )
ubara86
24
LA
I dont know why you need the harness from a 91 shouldnt you just be able to swap over the 87 stuff to the 91 motor, Its not like hes going 1J.:dunno:
SMP142
BOHICA
Jan 5, 2006
367
Tacoma, WA.
turbo2 said:
/\/\/\/\ it feeles like stock no slip
then whats the problem? as long as it holds the power then your good. i wish my setup felt like stock. my pedal is rock hard with no slipping really.
no need for a new harness, just switch the parts that need to be switched
it's all interchangeable (something I love about these cars)
ubara86
24
LA
Its pretty straight forward, line the engines up and whatever different switch it over. I don't know your automotive background but I'm getting a " I have never done a engine swap" vibe, if thats the case find a buddy who can give you hand, look over the tsrm and just remember how you took it out because thats how your going to put it back in. ;)
turbo2
59
hawaii
I know i have to switch some electronics but what electronics do i have to switch?
