Ridiculous 1000HP 7M Street MK3 Build
Albert
May 13, 2009
1,710
Tempe, AZ
mk3_7m;1974205 said:
hmmmz so guess that claims that Rich said about milbrum using his crank girdle was all bollocks.
No Gary was using the girdle for the longest time. His NEW setup currently is not using one
Florida
Got the head back from engine lab. Looks pretty good. Valve lash is right around the .008 to .009 clearance on all valves. It's a shame i will be taking it all apart to do the combustion chambers and shimless buckets.
Florida
Florida
I finished my measurements to order shimless buckets. Took some better pics while the head was apart. Can't get over the sexiness of the head :)
Albert
May 13, 2009
1,710
Tempe, AZ
Both intake and exhaust. Wouldn't you want them on the high end
Florida
Yep, I am going to make them as tight as I can when ordering the shimless buckets. .006 on the intake and .008 on the exhaust.
They actually weren't all .008-.009 when I took the time to really measure them. Here is what engine lab was able to do with just 100 shims I gave them...
intake exhaust
1 0.007 0.008
2 0.01 0.009
3 0.007 0.012
4 0.01 0.012
5 0.005 0.011
6 0.006 0.011
7 0.01 0.011
8 0.009 0.008
9 0.01 0.011
10 0.008 0.01
11 0.008 0.009
12 0.01 0.01
It's all within spec but it is a bit all over the place so I made an excel sheet that calculated the ideal bucket sizes to get close to the low end of the spec. I told the machine shop to just get close enough because I won't be using the stock buckets anyways.
intake exhaust
1 0.007 0.008
2 0.01 0.009
3 0.007 0.012
4 0.01 0.012
5 0.005 0.011
6 0.006 0.011
7 0.01 0.011
8 0.009 0.008
9 0.01 0.011
10 0.008 0.01
11 0.008 0.009
12 0.01 0.01
You do realise clearances close down as the engine wears don't you?
Most aftermarket Cams run closer to 13 thou, I set my shimless buckets up high end of spec +2 thou and as far as I know it's still running fine today in Crisp's car after many many thousands of KM's.
Florida
I didn't really think about that to be honest. I mean I know they do close up but after how many miles? I suppose I should really take that into consideration especially with higher lift cams and dual valve springs. I didn't order the buckets yet so I will bump it up to the high end of the spec instead. Thanks for the tip (both Albert and IJ).
NegativeGeForce;1974483 said:
I didn't really think about that to be honest. I mean I know they do close up but after how many miles? I suppose I should really take that into consideration especially with higher lift cams and dual valve springs. I didn't order the buckets yet so I will bump it up to the high end of the spec instead. Thanks for the tip.
You pretty much get one go to get it right with Shimless before it get's very expensive and time consuming...
I made the mistake of having the buckets Cryo treated after being assured that the dimensions don't change... they did with the open end of the buckets flaring out 2 thou...
Cryo Guy had to centerless grind them back to spec, as I posted I shot for High end + 2 thou and after initial breakin they were within spec.
Florida
Thats good info. What would I do without you guys? Probably on the side of the road somewhere in 6 months wondering why my timing belt broke.
Sent from my SPH-L720 using Tapatalk
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
that and valves are cut in with a interference fit
Florida
Been thinking about what Albert and IJ have said and I think the best idea for a newly machined head might be to just run stock buckets for a few hundred miles then swap in shim less.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well this is what I am going to do i going to run a large clearance by about 2 thou since most seating is roughly 2 thou max now what y can do is just place a shim under the bucket like I am going to do for my finale adjustment
in most case's a valve will seat down about 1 to 2 thou pending on how soft seat and valve are so it's best to ask your machine shop they will know
Florida
Well im sure the machine shop will say exactly what you said...valve will seat in 1-2 thousands. Best thing is to let it break in first before dumping 300 on shimless buckets.
SeeUSmile
249
Australia,Victoria,Melbourne
I never really thought about that.... Learnt something new today!
