redma70's full motor swap
slightly_red_MA70
Holy S*** I own a Racecar
Jan 24, 2009
417
Canada
nick88;1572697 said:
Buy universal kit from driftmotion, cut and mark it, and take it to someone that can weld it (aluminum).
Thats what I was looking at but its $240 and will probly take 2 or 3 weeks to get here. My uncle is almost the top guy at a local aluminum railing place and he said he can make me all my piping for cheap cheap cheap, which also means less couplers as most of it will be welded to fit to my car.(of course I'll have a few cause I'm not stupid and I know the pipes need to be able to move so they dont break lol)
slightly_red_MA70
Jan 24, 2009
417
Canada
My flywheel is on
Clutch is in
Pressure Plate is in
Trans is in
Starter is on
Just need a charged battery and I will be starting it up tonight :biglaugh::biglaugh:
slightly_red_MA70
Jan 24, 2009
417
Canada
Okay,
It's been a while since I've had an update.(Internet doesn't work properly at my house so I have to go to my parents)
The car started first crank....
-It ran good for a bit then started leaking oil,
-Replaced every seal on the front of the motor and all was good,
-Drove it for a bit more then took it off the road to do some more mods including, install of the Recaro seat and an oil filter relocation kit,
-Got it back together the friday morning of the 2010 PACNW Nationals,
-Drove to the drags and did a first ever pass with a 57 trim ct26 @12psi and the safc untuned and zero traction in first. Got a 13.966 at 103.3MPH,
-Did a second pass a little slower on the E/T but higher MPH,
-Got kicked off the track for leaking oil.......(this is when it all started),
-It was leaking from the oil filter bracket on the block......I tighten it up as for some reason it was loose. Still leaking.....So I leave it and figure I'll just drive it home and fix it later that night.
-I go to start up the car...Notice I have 0 oil pressure...Shut it off instantly!!
-There is now at least 3-4 liters of il on the ground under my car!!!!! :-(
-I push it out of the track and get it towed home
-The next day I take a look at it, I grab the bracket and it falls right off....without even loosening the bolt
-I look at the block and...half of the threads are gone!!!!! And I dont just mean the threads, I mean like a whole chunk of my block where there should be threads for the oil filter bracket is missing!!!!
-I now need a new block
So(sorry for the long story there lol), the motor had just and I mean JUST finished being broken in. There is maybe 600 to 700kms on the motor. I am a little ticked off now but shit happens I suppose.
I have a new motor lined up and it might come as a surpise to some of you........I'm going 1j :-D
stillboostin87t
Professional Lurker
Feb 19, 2007
47
NY
Damn, that sucks. I'm pretty sure you got a monster in the making though. Keep up the good work. Hopefully by then I'll have a build thread on here lol.
slightly_red_MA70
Jan 24, 2009
417
Canada
SupraRon;1595225 said:
Wow that really sucks. Did you over tighten the bracket? Thats tough luck man. Have fun with the 1J.
I'm pretty sure I didnt overtighten it, I think there must have been a crack or something.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
why not just change the block since you have everything all done ?
i can get u a spare gte just swap all the parts over? and get the block honed?
oorrr!
i can sell you my built 7m ;) LOL
