redma70's full motor swap
VanSupra
Van,B.C.
Remove all traces of viton with acetone and a brush. Coat with copper seal and let stand 45 mins to tack up, re spray once more before install and make sure that gasket falls directly into place with out moving around for fitment. All this can be done provided you didn't ruin either of the sealing surfaces. I have a lapping stone you can borrow for your block and head if need be. The honing should have been done at the machine shop, did your uncle not make you aware of this?
jdub
Feb 10, 2006
10,730
Valley of the Sun
redma70;1535537 said:
Yes it is a brand new Titan MHG
nick88;1535582 said:
If there is any of the coating coming off, you'll have to scrap it, if there is not, I would reuse it like it is, but I like taking some risks.
Brand new MHG - never been run. Tell me, what are the odds the viton will separate from the metal layers?
I have a novel idea - take the head off and take a look. The cylinders must be honed anyway and it just might be a good idea to assemble the engine in the correct sequence with the correct size bearings. I can tell you with 100% accuracy what will happen if you skip a step or take short cuts and it won't be pretty.
redma70;1535781 said:
Haha I know I'm just messin around with IJ.
Ummm...yeah, ok, right.
slightly_red_MA70
Holy S*** I own a Racecar
Jan 24, 2009
417
Canada
I took the head off and the headgasket is 100% fine. Im gunna send the block to the machine shop probly friday or saturday to get honed.
Oh, and I will be assembling it the right way now. I realize that I fucked up ok? We all make mistakes once and a while.
Dec 3, 2003
6,653
Canada
Good job Brent.
I made a mistake once, then realized that my mistake was that I wasn't mistaken in the first place. :rofl:
Duane
Nice avatar BTW lol
VanSupra
Van,B.C.
That's good..We all make mistakes some large, some small, but that was one they should use for an example at school..lol..I keed I keed..
slightly_red_MA70
Jan 24, 2009
417
Canada
UPDATE:
-Cylinders have been honed
-Pistons are in
-Bearings are in
-Crank is in
-Head is on and torqued down
-Timing belt is on
-Turbo mani is on
-Lower intake mani is on
-Walbro 255 is installed
-Purchased RC 550s (just need new lower o-rings)
-Purchased dual electric Flex-A-Lite fans (thankyou Arizzle)
Just need flywheel/clutch/pressure plate, turbo, EGR block off plates, and a few small random hoses.
I will get some pictures up in a bit. I'll also get pics of my "custom" engine harness and in progress wire tuck.
attachment.php
attachment.php
attachment.php
Heres the engine harness
attachment.php
Everything that usual crosses ove the front of the motor was moved back and will run down the other side of the motor.
attachment.php
Fans
attachment.php
Duane's old passenger seat (one more coming soon :naughty:)
attachment.php
And some pictures of the car itself the way it sits right now. It's dirty and covered in primer :nono:
You can see my tinted tails in this picture
attachment.php
Unfortunately my hood has been used as a work bench lately for all the small parts :3d_frown:
attachment.php
Thats all for now folks
slightly_red_MA70
Jan 24, 2009
417
Canada
Thanks guys!
I'm soo excited to get this running. I'm hoping to have all the parts next week and have it mostly together by next weekend.
And since I was told that red is the most expencive paint to buy I've decided between 2 colors...
Flat Black with a Clear Coat is my first choice
And my second choice is to go the cheap way and buy the "Duplicolor Paint Shop" - "Performance Red" color and just spray it with that....But I really want the flat black...
LAYZORBEEMZ
JZX73 owner
Jun 28, 2009
496
Maple Ridge, B.C.
The dupicolor gloss black worked out pretty good with my car, plus if you paint your car black and were at a meet I'm sure we'll mistake which car is which aside from the interior color since I am also now spoilerless :p
slightly_red_MA70
Jan 24, 2009
417
Canada
But I have no emblem on the front and I'll have a Recaro racing seat and cage in mine ;-)
slightly_red_MA70
Jan 24, 2009
417
Canada
Updates:
-Picked up my seat on sunday
-Bought main battery kill switch
-Bought 100AMP breaker
-Just ordered my clutch,EGR block off plates, and injector clips
-Bought AEM Analog type Wideband
-Bought 60trim CT-26
I'll get some pictures later when my internet is up at home
slightly_red_MA70
Jan 24, 2009
417
Canada
Pics as promised :icon_razz
Did some interior work(put everything back in). Heres the turbo timer
Comparison between my 60 trim and completely stock CT-26
Battery relocation started(just waiting on battery box), and pic of the switch.
Got my fuel tank back in and started the 12v relay mod
One of my new goodies :icon_bigg
Yes its analog...i wanted to be different and not have the same wideband as everyone out there lol
And the best goody of all :biglaugh: anyone recognize it???
Let's just say it's a matching pair with the other seat that I have :icon_razz
Hoping to get the rest of my parts(clutch, flywheel, and random small hoses) in by this weekend :biglaugh:
Dec 3, 2003
6,653
Canada
Doing things your way is a plus, the analog is different and it is most important that you like it. This is what makes us Supra enthusiasts unique; we all like different things.
I recognize that you need to do laundry. :D Nice seat too. ;)
Duane
