Enraged;1376288 said::: facepalm :: wikipedia is NOT a good way to back up your argument.
and as poodles says, it's not backpressure, its exhaust flow. when people say something increases backpressure, what it ACTUALLY means is a restriction in flow.
if you still don't believe me, go take a mechanical engineering course.
"backpressure" is to fluid dynamics as "centrifical/centrifugal force" is to physics.
Enraged;1376344 said:if you want a 4" DP on a vband, atpturbo has this cool item: http://www.atpturbo.com/Merchant2/m...tp&Product_Code=ATP-MDP-011&Category_Code=BCS
Poodles;1377248 said:WG is only opening when it trying to limit flow through the turbine, as such I don't see it being an issue at all as long as it's not spiking.
WG is LIMITING power, not adding....
fixed a bitjt2ma71;1377409 said:I'm loving my open wastegate dump.
But yeah, if you prefer to re route it to the dp, it's best to have the outlet merge with the exhaust flow instead of intersect. I've had re routed dump in my old seven M setup. You'd hear the exhaust note more under boost. With the open dump (2j setup), the exhaust note kinda disappears when the wastegate is open, old people expire, small children run screaming, birds fall from the sky dead and bricks in walls shatter
leecheater;1377624 said:My 2 cents. I have an open wastegate at present. I have not yet been hassled by the police and want to keep it that way. When I really get on the boost hard, it is VERY loud and it does stink. Sounds like this are cop magnets.
I took Rob, 92nsx for a short romp on the edge of a small town tonight. Just ran her through the gears all the way to redline in 4th. Really fast and really loud. I am calling tomorrow to have her plumed into my Greddy exhaust. This way at least I won't be advertising I just spanked another GT Mustang to the cops.
Haven't some of you been at minimum been talked to by the men in blue regarding your open wastegate??
Dan
leecheater;1377624 said:it is VERY loud and it does stink. Sounds like this are cop magnets.
sethron71;1377724 said:Haha I would just say what are you talking about, listen to the car as it idles. It is not loud at all, must be a mistake!! What is he/she going to do, make you make a pull to see if your wastegate is that loud? lmao
Seth
Boosted Supra;1377816 said:I think sound has a lot to do with the size of your WG. I have an HKS GT 60mm, never ever heard one of these with open dump.
