Rear BBK anyone?
IBoughtASupra
4,455
Queens, NY
Hey Mo, how come you didn't go with the non drilled and slotted rotors? Yes, I read you wanted to match the front brakes but it would have been less to get these rotors drilled and slotted than buying it already done.
Are they the same? They are 114.3. If you have a micrometer, do you mind measuring the thickness and diameter of the rotor? Thanks!
Here is the link. It says it fits 2005-2007 STI
http://m.autopartswarehouse.com/sku...ml?loc=Rear&tlc=Brakes,+Suspension+&+Steering
xzeror
1,356
Miramar, FL
dropped the hammer on a set of oem brembo rotors for a stealllll, all i need now is to get it bored to 60.1mm and buy new brake pads and im good to go. Any suggestion on pads? Ive been looking at the ebc red stuff.
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
I haven't had my rotors machined yet, but the calipers do indeed bolt on using the existing brake lines. The hardware screws right into the 'new caliper'.
xzeror
1,356
Miramar, FL
nice! ^ i think this weekend ill go get my rotors machined.
I still need brake pads tho >_< which pads were you guys doing this bbk going to use?
RedPhoenix
Kill it with fire!
Sep 23, 2009
222
Tampa, FL
Does anyone have pictures of them mounted on the backside besides the page 3 OP picture?? Im just having a hard time wrapping my head around the fact that these calipers really do just "bolt on" to the MK3 hub. Amazing.
xzeror
1,356
Miramar, FL
mmmmm i mean i am changing out my rear coilovers right now... its hot as fuck... might as well try it on and get some pics.
xzeror
1,356
Miramar, FL
evo caliper bolts right up, only problem i ran into so far is that the supra caliper bolts are a little too big. They only screw in like 4 threads. Going to order a set of rear evo caliper bolts, and hopefully that take cares of that :) pics are coming.
xzeror
1,356
Miramar, FL
Pics for those who are still skeptical ;), again this is only the evo caliper bolted on.
Mo87NA
1987 7M-GE &amp; 1991 7M-GTE
8
Upstate NY
This is true. I forgot to mention the MK3 bolts will not fit through the hub.
Luckily my calipers came with all of the associated hardware so it was not abig issue. Again, this is literally a bolt-on affair. Perhaps I'll take some time this weekend and get the rotors machined.
Thanks for the pics. I've been swamped with work and having been able to do much to the car.
-Mo
xzeror
1,356
Miramar, FL
-Mo
Do u know where i can get caliper bolts? Do these from rockauto look the same as yours?
http://www.rockauto.com/catalog/moreinfo.php?pk=3056580
Description: CARLSON Part # 14040
Front (Only 12 Remaining)
