I looked last night after work, looks flat! I'll have to check again in better light.IJ. said:Did you check the shroud mounts to see if it's mounting flat on the Rad or at an angle?
So you've seen cars with good condition mounts do it?bigaaron said:And from what I've seen it's not only a problem on cars that have broken motor mounts.
One would think, but my driveshaft carrier bearing is also shot so I get that clunk upon acceleration and deceleration.suprabad said:You'd think he'd feel it clunking around.
