I put in my PWR Radiator from 935 Motorsports last week, and I pop my hood tonight to discover 2 fan blades broken off on my '87 turbo. I know how much thicker it is over the stock unit, and I had it sitting flush against the radiator support. The fan and fan shroud were purchased new from Toyota at the end of 2005, beginning of 2006. When I installed the unit I used all new hardware and the shroud was mounted securely to the radiator with almost no play. Even now, there is no real play to the shroud, it's secure against the radiator.
What else would cause the fan to come in contact with the shroud? From what I could see tonight the radiator suffered no real damage from the disaster, one spot has a small dent but is not leaking whatsoever. It's just a little aggravating having to buy a new fan and shroud and put it all back together.
