How long? and how hard ? is it going to be taking out a rack & pinion replacing with a new rack & pinion on a 90 non turbo with the engine still inside ? any tip or idea would be nice ! already search but nothing came up !
If it is just the rack and nothing else its not too bad. Four bolts hold the rack in place, 1 feed and 1 return line, and the tie rods. Do yourelf a flavor and order some poly rack bushings from suprasport or some fresh ones from Toyota as they are almost certanly shot. Some new copper washers for the banjo bolts on the lines from Toyota would also be a good investment. The feed and return line are a bitch but if they need to be replaced do it while the rack is out as it is much easier without the obstruction.mk3tt said:How long? and how hard ? is it going to be taking out a rack & pinion replacing with a new rack & pinion on a 90 non turbo with the engine still inside ? any tip or idea would be nice ! already search but nothing came up !
:bsflag: :rofl: :runaway: and when was the last time you drank?ms07s said:If you lived here I would do it for a case of beer.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=SR&P=58 This will give you an Idea what your getting into.mk3tt said:any more idea
