From the Koyo Rad, it gets pressure thru the top fill neck over flow tube and then coolant is pushed into the bottom tank thru the former un-used coolant temp sender fitting. I'll try to get pics tomorrow 4U.1-2clutch-u;1998339 said:humm pics on how this surge tank is hooked up and all?
[video=vimeo;91123099]https://vimeo.com/91123099?utm_source=email&utm_medium=clip-transcode_complete-finished-20120100&utm_campaign=7701&email_id=Y2xpcF90cmFuc2NvZGVkfDZiYzNiMGY5NmYzOTlkOTM3MzZmODBlM2I0N2ZhOTBmNTIwfDI2NjU5MTczfDEzOTY3NTI1MzF8NzcwMQ%3D%3D[/video]miekedmr;1998057 said:Sorry to hear that.
Oil getting past otherwise-good seals would usually mean there is too much oil pressure on the supply side of turbo (need more restriction) or that the drain isn't draining easily enough and is backing up. With a relatively stock turbo setup it seems unlikely you'd have too much pressure at the turbo, though... Perhaps it comes down to poor balance like VIP suggested.
I picked up one of these too, they are really well made. your build is looking good as always. keep it up your thread fills me with happiness.Van;2000180 said:I received the Arizona Performance CT26 soft line kit http://www.driftmotion.com/CT26-Oil-Softline-Kit-p/dm390.htm ; so I can get the turbo off and back on w/o wasting my precious time!
I agree; the quality on the CT26 soft line kit is second to none.atmperformance;2000194 said:I picked up one of these too, they are really well made. your build is looking good as always. keep it up your thread fills me with happiness.
In general terns; In a closed system, its purpose is to neutralize rises and falls in pressure to prevent system failures, blowouts, and other problems. Keeping a system running in its ideal range is what it does.SeeUSmile;2000208 said:hmmm never realized the purpose of surge tanks. Good to know :3.
Exactly. That's how I got in the current problem... See post #578Backlash2032;2002269 said:Personally.. I'd order from Albert LONG before DM. Especially for turbo rebuilds..
Sent from my HTC6435LVW using Tapatalk
