R154 swap
Victor Charlie
161
Ann Arbor
I know I was a bit vague. If you are still stuck tomorrow, I will get more specific instructions for you. I worked out all this auto to manual wiring last summer, and I think I have a link or download, but I can't check it now.
Supralover87
Beauty and the Boost
May 21, 2007
84
Ohio
ok thanks guys for clarifying i'm female haha no offense taken... i get mistaken for a guy online alot actually lol (kinda sad really :nono: )
And if you can get the links for the wiring that would be awesome :)
and do you think it would be okay to use the manual ecu with the correct wiring setup?
Victor Charlie
161
Ann Arbor
This is from HamsMKIV on supraforums. it is for an MKIII, however. It is the best approach I have found. This allows you to use an automatic ECU. For a manual ECU you can do it more directly, but you will have to analyze the TEWD carefully to check all the harness wires and pinouts of the auto vs. manual ECU. The programming code for the auto and manual ECU's are different. THe same program, but it has several branchpoints where the manual and automatic ecu's are treated differently, and not all the code has been analyzed yet, so it is plausible that the performance would be slightly different if you use the automatic ECU. Since you have a manual ECU, far and away the best approach would be to swap harnesses and just use a harness for the manual ECU. It has to match the ECU color plugs and preferably the year of the body. IF you have a late 89 body, thats good, because it has all the wiring for any configuration or option that they made that year, so the manual harness should be good. IF you are trying to save money by reusing your harness, it probably is okay, but I haven't seen a paint by numbers recipe for making the harness conversion. It probably is very simple, but I don't want to say without knowing for sure.
anyway, here's the instructions if you keep the automatic ecu and harness:
just completed my 5 speed swap 2 weeks ago. If you have a complete 5 speed parts car you will have everything you need to perform the swap. Here's what you will need:
5 speed.
Flywheel and bolts off of the 5 speed car
lower "wing" tranny mounts that bolt to engine (they are different)
Inspection cover between tranny and engine
Driveshaft from 5speed
Pedal Assemblies
Master Cylinder
The whole swap is really easy. I've never tackled anything like this before and did it in 3 days. I could have done it faster but I was waiting on my clutch assembly so... The only custom work you will have to do is in the tranny tunnel. You MIGHT have to open up the hole for the shifter tower. I opened mine up a little and found out later that I didnt have to. I think it depends on the year model. All the holes are drilled for you to install the pedal assemblies and the master cylinder. One thing I would also recommend is that you have a braided stainless hose made to run from the master to the slave cylinder. The hard line is really hard to get out of the car because it runs underneath other hard brake lines and you wont be able to get it out. You could buy all 3 pieces from Toyota for about $65 or make a new braided stainless hose for about $35.
On to the Wiring:
As for bypassing the neutral safety switch... haha... I feel bad for the many people who have paid someone to bypass this..... I can give you a REALLY easy tip around this.... There's three harness connectors on the Auto... look for the one that is round and has three wires running in it, a BLACK wire, a WHITE wire, and a BLUE wire.... Cut that plug off the tranny with some wire to spare.... Take the WHITE and the BLACK wire and splice them together... Plug that connector into the harness side in the car.... Your ECT ECU will now think your car is in park all the time and it will start right up. Too easy.
You can then wire the clutch switch in line to the ignition wire that runs to the starter relay. It's a white wire coming off the ignition switch. You will only need to do this if you want to have a clutch safety switch, as it isn't necessary. Too easy there too.
The reverse lights I haven't gotten around to hooking up yet.... I will tell you that the harnesses are different between the auto and manual, but the wire colors (RED WIRE & YELLOW WIRE) are the same. therefore, get the male end of the harness off of the donor car and then splice into the male end of your car and you'll be in business. One of the 3 round plugs on the car side have the red and yellow wires to splice into. The manual reverse light harness is a TWO plug harness with a RED wire and a YELLOW wire.
The last one that you need to be concerned over is the Speed Sensor. It's a Rectangular plugged harness with 4 or 6 wires I forget. Anyways, they are identical between the manual and auto, so the manual harness will plug right in. This will enable your cruise control to work. The other wire you have to worry about for cruise to enable is the switch on the top of the clutch pedal itself. It opens the cruise circuit and disables cruise when you press the clutch in... I never hooked mine up because I have an aftermarket wheel and pulled my cruise module out. I will investigate further and get you an answer on that too.
That's really about it. Everything aside from the possible cutting is a bolt on afair....
Oh yeah, one thing I had to do... The hole in the back of the crank for the pilot bearing seemed to be a little to small for the pilot bearing to go all the way in... I used my dremel and sanded it open a tad bit to make a snug fit. That pilot bearing should be fully seated into the back of the crank if it's installed properly. You'll see what I mean when you get up in there.
That should be about it.... PM me if you have any questions or if I missed anything. You'll honestly be suprised at how easy it is.
Good Luck
Victor Charlie
161
Ann Arbor
I looked at the processor program code for the non-turbo ecu and it does have a branch point for manual versus automatic transmission in a segment of code suspected to be for fuel calculation. So I would think the manual ECU is worth fussing with to get it working on your swap. The proper harness would be the cleanest install.
Supralover87
May 21, 2007
84
Ohio
thanks for your research... i'm gonna just get it on the road for now and switch it back out when i can get my hands on an uncut harness....
Supralover87
May 21, 2007
84
Ohio
devrainey;1499729 said:
One of the round plugs has only three wires running to it and the two larger of the wires are the neutral safety wires. What you can do is to wire the clutch switch into the neutral wires so the car will start when the clutch is pressed. and when you let off of the clutch the car ecu will think the car is in drive instead of neutral.
I am happy to say this works beautifully :)
it runs it drives... but now:
Reverse lights = none did every red and yellow wire and that cannot be it lol
O/D off light any idea on how to stop the blinking?
Victor Charlie
161
Ann Arbor
Harness wires for the reverse lights are yellow wire and red with black stripe wire. The trick is that they are on two different connectors in the automatic harness, and one much smaller connector on the M/T.
devrainey
your a "*****"
Jan 13, 2010
33
George County Ms
Great:icon_bigg well im glad your getting it together.. Im having a bit of trouble with my swap still but im workin the kinks out. I haven even attempted to do the reverse lights but everybody seems confident on that situation so ill get to it latercheers to you for your success to this point. Do you do the work yourself or do you have help?
Supralover87
May 21, 2007
84
Ohio
ok i'll have to try this out... wondered if that might be the case but every thing i read said they were on the same connector, but tried them all and ran outta time lol
nick88;1502672 said:
take the bulb out or get a m/t cluster.
any idea what bulb it is? lol i don't really have a place i can just randomly take my car apart whenever... so knowing ahead of time helps lol
we found some simple ways to work some kinks out lol so i might have a comment or suggestion for yours lol i'll post if that combo works for my lights...
And my boyfriend and i make a good mechanic team... i do mechanical and misc and he does my electrical and fabricating :) I suck greatly at electronics and being creative lol
Supralover87
May 21, 2007
84
Ohio
ok lol never have torn into my dash... if it's not broken i try to not touch it or else it will break lol
Just go at it gently and slowly it's not difficult just fiddly.
I undo the steering column under the dash and let it hang down to make it easier.
Baggies for the screws help as well.
devrainey
your a "*****"
Jan 13, 2010
33
George County Ms
Lol im trying to teach my girlfriend a few things. Shes slowly starting to get more involved and learning things. So according to her im good for something :icon_bigg. Um the "kinks" im having are i have to fully press my clutch to the floor in order to get it to go into first or second at a stop. Ive already adjusted the pedal to the max and put a longer rod in the slave cylinder but its like its just not quite enough. Any suggestions supralovr? oh and the line has been bleed well.
Supralover87
May 21, 2007
84
Ohio
I have the same problem with mine in 1st and 2nd... but i'm a firm believer in peddle to the floor and i've never had any clutch problems(knock on wood) :icon_bigg
My biggest problems are a strange lurch under boost and i'm pullin 35lbs vacuum on the clutch so boost leak? not tttooooo likely but i'm looking into it...
MY biggest problems is it wants to stall between gears if i push in the clutch at a high rpm... if i shift quickly it'll catch it's self and be fine??? she's bitchy this is all i can figure at this present moment cause A/F says she's perfect in all throttle positions... :3d_frown:
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
Is your blow off valve recirculated?
Supralover87
May 21, 2007
84
Ohio
it's doing 45 at say 3500 in 3rd for example only... and i'll push in the clutch and go to shift and boom nothing in 1 sec flat... doesn't even sputter just shuts off
