I've been searching on here and SF.com to see what everybody ran and their opinions of course also their feedback for getting that multi-disk clutch. Still each thread starts out pretty good but dies off and the real answer never gets answered.
Am in the market for getting a twin disk, leaning more towards the OS giken ts2B clutch but good percentage went with the Spec but not much feedback. Also is their hydraulic slave cylinder finally fixed in their new kits?
Also what about rebuilding said clutch or if you found a good deal on a used but good clutch. Am mostly here looking at the OS Giken clutch. I was talking to RHDJapan and he mentioned on a flywheel replacement, i can use the sr20 Flywheel on their website to use with the R154/1jz setup. Hows that possible, isn't the two different bolt patterns, diameter or am i mistakenly wrong all together.
What i would like to get a good idea of your setup and how you feel about it. Plus an idea of what kind of mods you have and torque your putting down.
1. A multi-disk clutch will 2x, 3x, etc amount the surface due to having an extra clutch(es) and Saving your Engine Thrush Washer from taking in all that engine load
2. Bypass the Neutral Safety Switch- to avoid thrush washer damage on a dry engine with helps prolong engine life.
Bad:
1. Adjusting your hydraulic slave cylinder to avoid leaks or installing a bump stop.
Facts i've gathered:
Good:1. A multi-disk clutch will 2x, 3x, etc amount the surface due to having an extra clutch(es) and Saving your Engine Thrush Washer from taking in all that engine load
Bad:
