Ok tomorrow im dropping off my motor and this is what i know so far
Resurface head to RA below 15 (Tighten rear timing cover and tell them to leave it on)
Hot tank (Then replace Freeze plugs + Oil pump Bearings)
&& Make sure the AUX shaft still fits in the new bearings.
After thats all done and i bring it home this is what im going to have ready to put on and replace:
Clutch(Mine has about 50% left, gonna just replace it now) + ARP Flywheel bolts
Clevite Bottom bearing set (Question: Do i need to get ARP Rod bolts? Or is it just a good idea?)
Piston Rings (Question: MUST i get the toyota stock set? or is there another brand i can get thats a little cheaper?)
MHG
&& Other hoses that i see that will need replaced obviously.
Anything else ill need to check/replace?
Would it be a good idea to buy the
http://www.sipracingmailorder.com/servlet/the-338/Cometic-Full-Gasket-Set/Detail
for my rebuild?
HP Goal/Area: 300hp
Another question lol sorry: During the re-assemble part what are some sealants or whatever im gonna need?
Im having shane from nolden motorsports come and help on the re-assemble and i'd rather have everything needed
when he shows up.
Also, what about the crank? i thought i seen others having to have it honed or something?
