Question: Helium in space
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
wow physic class all over again:aigo: had a head ack for a week after that specal relitivety stuff
that flame was F$#$ing awsome
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Assuming that the baloon was just left in outer space by itself with no spaceshuttle around, I'd say it would slowly go towards the closest/largest gravitational mass near it (like a planet or a sun).
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
bigunitpitcher22 said:
The balloon would rise because helium is less dense than air, it's not "lighter" - it's less dense.
A hammer is lighter than air and it doesn't sink in space. The point is that in zero gravity nothing has any "weight" in spite of its mass, therefore a balloon would just hang in the air just the same as a hammer or astronaught.
If the balloon was moved from a vessel containing air into the vacuum of space itself, then the pressure differential between the inside and outside of the ballon would exceed the strength of the latex and it would pop.
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
Using lighter is correct, 1 gram of helium is and always will be lighter than one gram of nitrogen, where density is mesure of mass per volume, theoretically the balloon ( given that the material of the balloon would only expand minimally and hold a massive amount of pressure) would begin to sink with more and more helium, as its weight being pressurized within the ballon would exceed that of nitrogenous air, here density would in fact be incorect, you cannot describe an element as being dense without a volume.
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
I was assuming there was a form of gravity, as an air like environment could not exist otherwise, it can however in a low gravitiational environment granted it will be different, thus there is weight as there is a a force acting on the mas of the gassess
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
The baloon would rise to the bouyance relevant to its own density. If it were in space, there would be no opposing force so it would pop, outward of course.
*I did not read byond the first post before posting*
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
:umno:
Incorrect..Measured in the same location, 1 gram of helium would NOT be "lighter" than 1 gram of ...anything...nitrogen, lead, feathers, dog shit...its doesnt matter the substance. 1 gram is 1 gram. The volume may be quite different to be sure. And good luck weighing a gram of helium...but thats besides the point
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
Um...gram....oops...i meant a quantity, reffereing to soemthing like the feather and brick analogy, i think i got a little confused typing.....i guess thank you for clearing that up, sry about the mistyped information ( i was thinking volume in a contained area )
although what you worte is somewhat incorrect also, within different gravtitational fileds a gramwill weigh much less/more than a gram within a different gravitational field ( its mass however will reamin the same of course..)
and weighing gass isnt that hard
bigunitpitcher22
BoL Spartan051
Jun 13, 2006
158
vancouver, WA
If there were no gravity, everything would just fload, the gasses would not be able to separate from eachother. An example is of astronauts not being able to belch because the gas in the stomach cannot be separated in zero grav.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
You bodies muscles should be able to forces out any gas from your body regarless of it coming from your mouth or your arse. I can't remember what show it was on, but Steve O was in zero gravity and was able to puke his guts out. If that can be done, then you should be able to burp or fart.
