Question: Helium in space
MDCmotorsports
Indy 500
www.MDCmotorsports.com
We all know that helium is lighter than air.
And a helium balloon rises due to the fact its lighter than the air around it, and it reacts in the opposite direction of gravity - it goes up.
What happens when you put that same balloon in an air enviroment, but with zero gravity?
lagged
1991 1JZ
new rochelle
well its not reacting opposite to gravity, per se. it rises because of the same reason and air bubble would rise to the surface of a body of water.
forget the fact that eventually the balloon would pop due to the decreased air pressure the higher the balloon rises, if the balloon was able to survive that, it would only rise so high. it depends on the concentration of other gasses at a given altitude.
i do not know what the make up of the upper atmosphere is though so i couldnt say where it would stop rising.
once a gas is released, it expands as quickly as possible in all directions in order to reach an equilibrium with the other surrounding gasses.
so, in a zero gravity environment with | 1 bar | of air pressure, i suppose the balloon would just stay where ever you put it.
exander
Anything but Lurker
May 23, 2006
22
colorado
Ckanderson said:
would sink due to the weight of the ballon?
It couldn't possibly sink, weight is only the amount of gravitational pull on a subject, thus the balloon would just hover around only moving by an outside current.
MDCmotorsports
Indy 500
Thats just it... helium balloon inside the space shuttle. Its lighter than air, but with no gravity to react to, where would it go?
RacerXJ220
Interdimensional
Abalama
It would go to where the air around it is less dense. It wouldn't go, up, down, or anyother way in zero gravity. Gravity causes the air to be more dense near the surface of the earth, but once you release those balloons into the air, they only go up so far. Once the outside air becomes as dense as the helium inside the balloon the balloon will no longer gain elevation.
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
Like anything with mass acts in a zero gravity environment ( wchich is partially farse, as there is a given gravity from other objects in a space shuttle) it will move perpetually in the same direction it was initially moved, however, balloons function becuase of the difference of pressure outside/inside the ballon, the pressure in space is nearly zero so the ballon may pop....( depending on the stress capacioty of the material and thoe forces acting on it)
* just realized teh first post siad "air environment" therefore reffereing to a nitrogen envirnment, where the ballon would rise still as helium is a much "lighter" gas than nitrogenous "air", gravity actually interferes with the ballon rising, ( On earth the helium must first overcome the weight of the ballon before it rises, in a zero* gravity environment it does not need to overcome that barrier ( as his post said in an "air" environment
koulee
497
It would do the same thing a lit match would do in near zero-g: take the shape of a perfect sphere.
Supra
304
Rockford, IL
:ttiwwp:
I want to see a round ball of fire on the end of a wooden match stick.
