I'm planning on getting a MAP Sensor from a japanese MKIV since its a straight swap to my MAP Sensor but is a 2 Bar IIRC compared to my standard one being a 1 Bar.
The question is... has anyone on here done this yet and if so, what was the new boost cut level at?
The 2J MAP Sensor won't remove the boost cut, just push it to a higher boost level since it reads in a different voltage range then the 1J sensor. I'll have an SAFC to add fuel as the 2J sensor swap makes the car run quite Lean due to its different voltages it outputs to the ECU.
