jdub;946548 said:At least 5 heat cycles (that means complete warm-up to cool down cycles) ...the sooner the better once that point is reached.
It's your call...once coolant hits the bearings, the damage is done. I would do an inspection at least, but if you chose not to do so, get some WalMart SuperTech oil (5W-30 if you can) and filters. Put it in, pull the EFI fuse and crank with a fully charged battery until you get pressure. Install fuse, and crank, idle for a few minutes, drain and replace. SyperTech stuff again, this time run for a 100 miles or so. Drain and replace with your favorite oil.
87mgte;948763 said:Well alright then, a retorque after 5 cycles should be no problem. Why SuperTech, any particular reason? I'll be using 10W-30 Royal Purple after the flushes. Pretty stoked to be able to say I'm the only one at my high school with purple oil.:biglaugh:
gaboonviper85;948771 said:I would recomend a 0-30w royal purple....but thats just me....unless you plan on raceing and your engine temps are above average then light oil is usually your best bet for wear resistance..
87mgte;948805 said:Seriously? :dunno:Wow I had no idea... thanks for the info.
jdub;949243 said:SuperTech is cheap and it's a decent oil (and filter)...especially since you're going to dump it after a short period. Once you go to a syn oil at the 1500 mile point, use Wix or PureOne filters.
jdub;949243 said:WalMart SuperTech oil (5W-30 if you can) and filters. Put it in, pull the EFI fuse and crank with a fully charged battery until you get pressure. Install fuse, and crank, idle for a few minutes, drain and replace. SyperTech stuff again, this time run for a 100 miles or so. Drain and replace with your favorite oil.
jdub;949638 said:I was talking about flushing with conventional oil at the 100 mile point...sorry, should have been more clear in the 2nd post. The earliest I would switch to a syn oil is at 1500 miles on a motor that needs to be broke in. If the rings are already seated, you can switch right away after you flush.
Read this on break in:
http://www.supramania.com/forums/showthread.php?t=48993
There's a lot more to oils than one would suspect
jdub;949674 said:Yes you can...hope it works
gaboonviper85;946743 said:Shop is ISO 9001:2000
Oh and if you are into bikes we are the machine shop that makes the highend cannondale aluminum cranks....goes to show that cannondale is serious about quality
slidebabyslide;946797 said:Cannondale is still around?
