Figgie is no slouch
I'm a believer in getting the decks as smooth as possible, but it comes to a point of diminishing returns and expense...mirror smooth is subjective as figgie pointed out...RA spec is not. If you're going with a OEM HG, a surface RA of 50 is plenty good enough...but, if it can be done smoother for no additional cost, yeah I'd go for it. A final lap won't hurt either. Like I said, flat with a stock HG is just as or more important.
ARP head stud spec is 80 ft/lbs using moly for lube. Torque in the TRSM sequence in 10-15 ft/lb increments. I highly suggest a re-torque after a minimum of 5 heat cycles...there's a thread going on now about that.
Concerning an oil flush...did you have coolant in your oil? (it appears so)
Did you run it and how much with coolant in the oil?
Is the motor in the car or did you pull it?
