Hello everybody!
It's been a while since I have posted some of my upgrades.
Anyway, I was reading threads about swapping the V160 6 speed in the mk3 MA70 Supra running a JZ engine
of course, and the information about it is quite poor , and no one HAS DONE IT PROPERLY unfortunately. I am
not satisfied with just changing 6 gears after the gearbox installation. Everything related with oem stuff must work
properly, and nobody has done it till now.I just bought a used V160 transmission same days ago and I am going to
start the work on it very soon.
Installing the V160 / V161 6 speed transmission in a mk3 will need the following modifications :
- Shifter linkage of the V160
Is too long and it must be shortened to fit our oem mk3 chassis shifter opening / hole.
SOLUTION : We will customize the V160 shifter by shortening it around 4 inches and tig weld it after that.
SOLVED
- Linkage rod of the V160
Is too long also and must be shortened same length as the shifter linkage
SOLVED
- Shifter rubber boot & leather trim of the mk3 Supra
mk3 Supra manual transimssion rubber boot and leather trim hole is too small, and must be modified to fit the mk4 shifter.
SOLUTION : We will customize the shifter rubber boot & leather trim by opening and cutting the hole to the mk4's shifter size.
SOLVED
- Transmission crossmember modification
The mk3 R154 or W58 oem transmission crossmember will not fit,neither the JZA80 mk4 V160 will do.
SOLUTION : We will customize probably the oem mk3 R154 cross member to make it fit with the V160
SOLVED
- Driveshaft
The mk3 driveshaft or the mk4 driveshaft won't fit
SOLUTION : We will go custom on the mk3 or the mk4 shaft,but will have to leave it for the end after all other stuff are on the car.
SOLVED
- Gearing
We must go lower on the rear differential gearing, as the mk4 V160 used 3.1 or 3.2
SOLUTION : We must use the MA70's lowest gearing which is 3.7. We could get the aftermarket 3.5 gear which fits our 8" diff and use
a bigger tire wall to lower the gearing more, like a 285-40/18'' which will also provide more traction. This size is also produced by MT !
PENDING-SOLVED
Also, when you drop the manual W58 or the R154 from the car, we disconnect the following, which are located in or on the trans and
we must resolve these issues with the V160 swap :
- Speed sensor
It drives the speedometer in the cluster and produces the pulse for the speed sensor operation and speed signal feed to the ecu,
and is needed for the car's operations and it's systems..... like ABS, Power steering, TEMS, Cruise control, Super monitor,etc.
SOLVED
- ABS sensor
The ABS sensor that controls the rear wheels is located on the transmission and transmits the signal.
SOLVED
- Reverse / Buck up lights switch
It is located in the transmission and is needed when we put in reverse to back up the car.
SOLVED
Anyway, I will take every issue and post what I will have to do to resolve it and upload pictures.
Also I will upload pictures of stock oem parts, aftermarket , and custom parts that will be needed in the process.
I already purchased from the dealer the oem parts, and a few other aftermarket and custom parts needed for the V160/V161 swap.
I got already from Toyota dealer the following...
(after I did my homework of exaclty what I will need to purchase)
# Shifter parts for the V160
# Bell housing parts (service plates,bellhousing bolts)
And of course I will need to purchase a mk4 JZA80 multi plate clutch since I am hitting 4 digits HP,
so I got the following clutch parts.
# Clutch parts (release fork,bearing,hub,shims,washers,pin,wave washers,etc.
And some driveshaft oem parts for the JZA80 shaft:
Now I am ready for work with the 1st step, modifying the V160 shifter linkage and rod linkage.
Stay tuned. You can post any ideas or comments about this swap project :icon_bigg
SOLVED
SOLVED
SOLVED
SOLVED
- Driveshaft
SOLVED
- Gearing
PENDING-SOLVED
- Speed sensor
SOLVED
- ABS sensor
SOLVED
SOLVED
