project who said supras are to heavy for track cars
disturbed1
372
perth
well this is the condition in which i picked up this supra. as u can see its nothing flash, however it did contain a few goodies such as the r154 gearbox, which at the price i paid for the car, was good enough reason to buy it.
rather then stripping the parts and getting the shell taken away and crushed, i decided to turn it in to a cheap track car project. since i am on a tight budget, the main emphasis on this car was to try and get it as light as possible.
since alot of work has already been done so far, ill let the pics to the explaining as it woul dtake far to long for me to type up the history of it.
as it stands, the spec list is as follows. items which are in bold are temporarily borrowed from my soarer (reason being this car was slapped together in a very short peoriod of time b4 the end of the drag season to get a few passes in and see where i was at,
i want to do a couple more track days while the running gear is still in the supra b4 i put it back in soarer - i know it sounds like alot of time wasting swapping parts over etc but dont have finances to rebuy everything atm).
Engine and mods
1JZ GTE
Custom 2-1 exhaust manifold using stock twin manifolds
Aeromotive fuel pressre regulator (with Redline fuel pressure gauge)
600x300x75 mm intercooler
2.5" hot side and 3" cold side ic pipes
3.5" side pipe
Eboost 2 electronic boost controller
garrett gt3040r (0.82 rear)
Trust type r 50 mm external wastegate with 0.8-1.2 bar spring
Tial bov
Ems 8860 ecu
MSD 8.5 Ignition Leads
5 gallon rci fuel cell
bosche 044 external fuel pump
Transmission and driveline
R154
modfied stock pp and puck clutch
4.1 welded diff
Stainless Braided clutch line
Suspensions, wheels and brakes
Regamaster: 17 x 9 +38 and 17 x 10 +40
Cusco zero2 coilovers
Cusco front strut brace
Braided stainless brake lines
Cusco brake master cylinder stopper
brakes: front - nightpager bracket, nissan 4 pot calipers, 324mm dba5000 series rotors, endless pads
rear - custom brackets, nissan 2 pot calipers, 324mm rda rotors, endless pads
hyraulic handbrake - operating rear calipers
whiteline adjustable swaybars back and front
Interior
bride zeta3 on side mounted fixed omp rails
sabelt 4point 3" harness
deka dry cell battery (weighs 7 kg)
Autometer cobalt 5" monster tacho with shift light
on another forum, this supra was a project to try and run a 10 for under 5k, however, due to funds and the urge to get out there and drive it, the direction
changed and it is turning into more of a drift car, yet will see the drags when i have a motor powerful enough to run the times i want. the budget is still an important aspect of this
projects so ive been keeping a tally of almost every cent ive spent on it, and all money ive mnade from selling parts off it, sorry its not in the best formatt but u get the idea,
NOTE: all these prices are 100% real, not fudged or made up and ill keep them updated as the supra progresses
PRICE UPDATE
Initial purchase of car..............................$1400
Tow home.............................................$120 (thanks anytime towing)
Rego Transfer........................................$24
Paint stripper..........................................$12 (tidy'd the rims up big time to a state someone might wanna buy them)
stage 1 paint supplies ............................$117 (total paint)
inc sandpaper, spray putty primer,
body filler, thinners and flexiprimer
stage 2 paint supplies..............................$270
1.5 ltr of red, 2.4 ltr of black,
2 ltr of hardner, good quality thinners
more thinners........................................$27
stage 3 paint supplies
more red and black paint.......................$160
polishing pad..........................................$30
9 inch polisher/grider for polishing .............$150
fixed back seat......................................$750
omp rails...............................................$75
mt street ET 255 60 15...........................$450 (A1 HI-performance)
5 gallon rci fuel cell................................$220 (A1 HI-performance)
spray gun.............................................$120 (cashies malaga)
air compressor and fittings.......................$105 (bunnings)
safety 21 6 point roll cage.......................$400
hks sport turbo - balanced and serviced by grant (per$manz)....$100
ally straps for fuel tank ............$15
fittings and fuel lines.................$190
044 fuel pump..................................$220
2.4x1.2x1mm ally sheet....................$45
window switches...............................$20
electrical wire and blade fittings.........$30
cable ties............................................$10
1x tight radius 3" ss bend..................$55 (since been replaced but will keep in total cost)
gt30 dump flange................................$45 (since been replaced but will keep in total cost)
battery................................................$200
sabelt 3" 4 point harness....................$350
stern rims 17x9" and 17x10.5" (+50)...$550
brakes, nissan 4pots/2pots 332mm rotors...$1050
whiteline adjustable swaybars..............$270
4.1 open diff +bulk welding wire..............$150
hydraulic handbrake........$400
fittings and hardline.........$20
braided rear lines............$80
brake fluid........................$20
pinch weld..................................$20
godfather front bar..................... $320 (+ stock bar/nose cone/indicators/grill)
cusco zero 2 coilovers.............$550
t78 33d 17cm.............................$400
HID lights ..................................$75
oil filter/motor blocks.....................$160
braided teflon oil feed....................$60
2 3/4 - 3" 90 degree silicon bend..... $60
3" 90 degree silicon bend ............... $63
2/34 90 degree silicon bend ...........$53
20mm silicon bend (oil drain).......... $20
2 3/4 ally donut (welded).............. $70
1meter of 2 3/4 ally pipe............. $30
0.5 meters of 3" ally pipe.............. $30
welding..................................... $50
3x3" s/s bends.....$80
2x -6 straight joins and 2x-6 90's, 1.5m -6 braided hose and 3x bolt clamps $150
ls1 coils ...................................$130
braided fittings for catch can...............(yet to pay)
msd 8.5mm spark plug leads..........$100
regamaster rims $1200
work rezax rims $600
f50 rear brakes $1400
billet alluminium for caliper brackets 100
stoptech front brakes $1300
shineauto rear pods $230
exhaust manifold $200
hks manifold $300
hks cam gears $300
sard rail $130
fluidampr balancer $375
plenum and tb $500
hks 272 cams 700
work meister rims (pair) 550
sard injectors 500
greddy hydro pully 80
oil cooler kit 320
bomex side mirrors 150
fiberglass doors and moulds +bonnet mould 250
silicon intercooler joiners 150
ITEMS IVE OBTAINED FOR FREE
side mouldings
aftermarket sideskirts
MONEY MADE FROM SELLING PARTS WHICH CAME WITH THE VEHICLE
r154 gearbox .............$1250
hks sport turbo...........$1100
hks hiflow turbo elbow...$100
speaker door pods..........$40
GFB BOV.......................$60
shitty boostguage..........$20
ignitor......................... $20
2 wheels.....................$100
grills............................$55
factory dash................$220
isc valve......................$20
factory injectors............$80
factory intercoller..........$50
2 wheels scrap man.......$20
muffler............................$55
3.7 factory?? lsd..............$300
engine mounts .............$50
anyway - on to the pics of the build up
enjoy
disturbed1
372
perth
disturbed1
372
perth
this is the state as which its at now.
im yet to hit the track with the new seat setup or with the new brake setup.
i had to take drastic measures to the floor since being 6"2, a helmet and a roll cage meant my head couldnt sit upright without touching the roll cage.
im very happy with the way it all turnout out though.
been looking at ordering a set of hoosier radials (245/295) before i hit the track next which would completely transform the car for sprint/time attack events
92nsx
2,957
Clearwater, MN
Looks good man, you know what it tips the scales at?
Also using cooling fans in a pusher configuration, they are only %80 efficient vs. using them in a puller configuration witch will allow then to be as efficient as possible;)
SupraMario
I think it was the google
7
The Farm
Holy shit!!! That some badass work man!
At first when seeing the paint...I thought thats ugly as fuck...
then the picture with it all put together(sorta) it looked nice.
great work keep us posted.
disturbed1
372
perth
j3pz;1117314 said:
wow looks awesome. when you get some track time, try to get some footage, would love to see this in action
ALL CLIPS ARE WITH 350 HP (14 psi)
officials wernt happy with my side pipe burnouts noise level given it was suppose to be a street meet
http://www.youtube.com/watch?v=d5itq2cYrC8
hows this for a bog - note to self - never attempt drag racing without a tacho. officials also didnt like the oil i was burning up either- 7m oil dipstick design with an o-ring seal is gayest idea
best run for the night was 12.3 i think at 116 mph. was pretty gutted it didnt run 11s cause it feels a shit load quicker then my soarer which ran a 11.8
http://www.youtube.com/watch?v=rBLgLillw3Q
2 clips at ahg - as u can see - i like to to use the whole track and hit cones
(nothing flash but other then 3 drag passes - this was first time i had driven the car - ive never done drifting b4 either so im just learning and as u can here in the background of 1 of the clips, my previous car was a fwd saab :))
http://www.youtube.com/watch?v=ejbK54DkRdI
http://www.youtube.com/watch?v=LLQpe_G0QoA&NR=1
disturbed1
372
perth
last time i was at the drags, the officials had a big whinge about no door trims so i just made these up yesterday out of .5mm thick aluminium
also pulled the rear bumper off to paint it properly. since ive got no fuel tank etc and the bumper had the potential to trap alot of air - i cut out 5 rectangular slots which will be filled with mesh. will upload som epics once painted. thought the car looked pretty tuff with no bumper so took a few snaps. b4 anyone comments - havent had a single problem with the o44 mounted as is
disturbed1
372
perth
yeah im aware they arnt as effective in push config but this setup was borrowed from my soarer which i decided to go push inorder to keep the engine bay as tidy as possible. havent had any dramas with it so far. worst case senario - could run the factory fan as well
JASONA70
nomnomnom
Oct 27, 2006
743
socal
the vids were awesome, the car actually looked pretty light taking on those corners. the car looks and sounds great, any more vids of autocrossing?
disturbed1
372
perth
dont have any uploaded but if i feel like devoting the time it takes to upload them on youtube (about 3 hrs) ill put some runs up.
the weight is a bit of a sore point with a few other supra owners on here and supraforums but i have unofficially weighed it in at 1180 kg with a full 20 ltr tank of fuel back when it had lighter gtr rims on, no roll cage and factory brakes.
that weight was at the state drag strip so i cannot confirm it was accurate to a kg, 10kg or 50 kg
i lost 15 kg in upgrading brakes alone so id say id be close to 1180-1190 kg mark. shame im a solid 100kg and not 70 (as far as weight for racing cars go)
disturbed1
372
perth
was getting late and loosing interest so is a little rough with a bit of shit in it which ill just polish out but atleast the bumpers painted and 100x better then it was.
wonder if my speed holes help. will fill them up with black mesh tomorrow.
also painted the rear light center garnish and the rear trims so the backend should look almost complete once bolted back on.
still saving up for bopmex rear add ons though
Alpinesupra
Cars never talk back
Apr 6, 2005
138
mckinney, tx
looking good bro, i like what you have done with the car.
keep up the good work.
ive also pm'd you about your tko500. (edit, i cant pm you your mailbox is to full)
thanks
-sean
disturbed1
372
perth
gtimportfanatic;1118037 said:
good shit man.. love the things u did so far. how hard is it to remove the front and rear bumper?
like everything on cars mate - just a matter of unbolting anything which is either in the way or attaching it to the car. given i dont have any interior trims etc - theres a lot less involved. i dont have any bumper supports and i know the rear bumper is held on by about 6 bolts and the front by about 4 (and 6 cable ties)
i want either a greddy bar or a doluck (demon) or a godfather. i missed out on a brand new godfather front bar for 400 dollars :( was pissed. current bumper and bonnet are just sprayed black with a can just to look half presentable since the car required bumpers to drag race. they both temporary items
