Project Spoolnup 7M
yota8791
242
virginia
well here it goes, so just got the loan finalized two weeks ago and got the parts orderd. heres the current mod list:
-je forged pistons (8.2.1 compression)
-stock rods
-bored .20 over
-block has had .10 milled off the top (or so i was told and charged for)
-crank has been turned 10, polished and balenced
-head has been decked to match (or so i was told and charged for)
-full valve job (or so i was told and charged for)
-fully ported and polished head (or so i was told and charged for)
-ported intake manifold (or so i was told and charged for)
-ported turbo,
-new oem replacement cams,
-greddy 20g turbo with new internals(21psi and climbing hehe)
-hks intake pipe
-Fake spearco w/ greddy hard pipes
-Tial 50mm bov
-Sard FPR with steel braided fuel line
-550cc rc injectors
-Walbro 255 fuel pump
-ACT stage 3 6-puck sprung clutch
-3in elbow, 3in piping
-HKS super dragger exhast
-aem ugo wideband
-ngk plugs and wires
-hks electronic boost controller
-hks turbo timer
-apexi neo afc
-rush anti-lag system
-HKS steel beaded 2mm hg
-M/T ET streets for racing
this set up only has like 4k on the rebuild so its time to upgrade lol, i will have many parts for sale soon so just check the classifides, but anyways heres some pics of the motor pull
yota8791
242
virginia
the new mod list:
Garrett T-67 ported and polished .70 compressor housing, .84ar exhaust housing, 67mm wheel
aem ems
aem 5-bar map
aem iat
tubeular exhaust mani
50mm tial wg
1 peice steel ds from drive shaft shop
Brian crower stage 2, 264 lift cams
bosh 870cc injectors
fmic
sethron ffim
80mm cnc'd throttle body
fidanza cam gears
hks dli twin fire ignitor
8pt roll cage from swracecars.com
thanks to aspsrt05 and pantherballhp at tached out performance, you can check them out on fullthrottleforums.com, they will get you the hook up
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Just a heads up. That cage will require ALOT of modification. You will need a tube notcher and a chop-saw. VERY tight for aftermarket seats. I ended up only putting in the drivers side door bar. You also will want to up that pump. As far as the list very nice and it resembles mine. Should be a nice increase in power.
yota8791
242
virginia
thanks all, yea im excpecting the worst with the cage but im having one of the best welders around install it, and we r just gonna see how the single 255 does at first, if its not enough we r gonna do a twin 2jz pump set up
yota8791
242
virginia
well got everything done and dynoed, on pump gas 93 it made 461hp 411tq on 17psi. thing ran like a raped ape. went to the strip, my second pass the trany blew into a million peices, shattered the fly wheel and clutch, put a hole the size of a football in the floor board below the gas pedal, broke an ear off the block where the bellhousing mounted, tore up my ecu harness cut the brake lines, and put a nice dent in my hood. i will have the dyno and run vids up soon along with damage pics, if anyone has any leads on a trany id appreciate the input. but it looks like im done for a while :cry:
whitemike
1,164
Winter Park, Florida, United States
Looking good, although I must say be careful with the loan thing. The problem with payments on a modded car is that if it breaks you usually need good money to fix it.. then you're stuck paying off a car on stands!
Keep up the good work!
Suprapowaz!(2)
2,870
San Antonio, Tx.
Did you happen to read his last post?
yota8791
242
virginia
whitemike;1594060 said:
THAT FUCKING SUCKS
Wow, @OP: I'm so sorry to hear that. It makes my previous post seem harsh, what do you need to get it back up and running? If the block is OK I'm sure that ear can be welded back on, and the rest can be repaired!
its ok man, well we're actually wondering if the trans is bad cause it will still go in gear, we r hoping its just the bellhousing mabey an input shaft? we are gonna check the back of the crank and all, but if its bad i just picked up another block yesterday with the full rotating assembly in it and we'll just punch it out and clean it up and swap over the parts. gotta pull the dash and all to fix the fire wall, gonna have to run new brake lines where it cut them, gotta fix the wiring harness, new flywheel and clutch. just hope it didnt get my new drive shaft or fry the aem.
yota8791
242
virginia
We actually had someone build the motor the first go around and he put everything back together and turned the flywheel and today we got everything apart and took what was left of the flywheel and clutch bolts off with our fingers. Which it isn't the first thing we have found only finger tight that he put back together. Back of the crank is slightly damaged not sure if it can be machined out. Haven't got to get into internals yet. Its also looking more like just the bellhousing that exploded, the actual tranny is still in tact. I will try to get vids and pictures up tomorrow.
yota8791
242
virginia
well the trany is still intact just the bellhousing and the front carier bearing cover is damaged, we backed what was left of the flywheel bolts out with our fingers, even the broken ones. they had no loc-tite or nothing on them, so the guy that put it together could have very easily killed me with his carlessness and he'll get away with it cause it'll never hold up in court. my tuner, x-man, said it didnt even look like the flywheel had been turned at all, and he said if it was it wasnt done right. so if any of you that read this are near christansburg va and need motor work done, do NOT take it to pro engines. here is the vid of the explosion:http://www.streetfire.net/video/thomass-clutch-and-flywheel-exploding_2039715.htm
yota8791
242
virginia
here is a rough draft of the new parts list, not including all the body work
-quater master twin disk capable of over 800ftlbtq
-fidanza flywheel:aluminum
-eagle h-beams
-hks 2mm stopper mhg
-je rings and seals (.020 over bore)
-aeromotive 11101-a1000 fuel pump
-aeromotive fuel filter12335-40 micron, obr-10 red fuel filter
-rci drag race 12gal fuel cell (with foam)
-coil overs
-ferrea valve train
-a1 rear traction arms
-cusco type mz lsd
-racing seats
-replacement aem uego wideband
-arp rod,main and flywheel bolts
-beech solid motor mount
-marlin crawler built trans
-have the block and head re-machined
and im debating on a stroker kit?!?!?!?!
the funs just begun hahaha
