Ok, so the motor is in. Timing seems to be just right, but she still misfires a lot. Car randomly shuts off, so I am going to check all of the relays and fuses. There is nothing grounding out, the engine wiring was done perfectly this time.
Second issue, oil pressure is running close 100psi when cold. Once warmed up she comes back down to about 21-22psi at idle. If the rpms are above 1K, the pressure shoots up to about 60-80psi tops as the revs go up (20psi> 30psi> 40psi> 50psi>etc...), depending on whether we are sitting or driving.
Third issue, oil is pissing out of the block on the intake side, and appears to be just beneath the upper coolant neck. This happens whether we are idling or driving. There is coolant in the head again too. There is no blown MHG though and the car is strong when driving. The head was properly torqued and re-torqued after a few heat cycles. There is a galley there between the block, head, and rear timing plate that sits behind the cam gears. Its large enough to fit your pinky into and this appears to be the source of oil/coolant escape. Anyone know anything about the 2jz's and what on earth is suppose to be here? I am posting on supramania and clublexus to see if anyone has any idea.
Im VERY close to trading this vehicle for a K5 4X4 Blazer, or any lifted truck or nice V8 vehicle. Yet, I want to stick with this...
Owning a supra is a love/hate relationship. Seriously. And I mean the throwing-shit/yelling-and-then-crazy-make-up-sex kind of relationship. :3d_frown:
