Eh, not yet. So ran into some complications...
1) Snapped the V-Band clamp from DM. I thought these things were suppose to keep going until the exhaust was sealed??? It wasn't even tight and was threaded properly AND I had someone hold the DP so it wouldn't put strain on it and the bolt and nut snapped in half...
2) I need to get a nut so we can weld that onto the upper oil pan and then I can put on the last half of the turbo drain line. Apparently no one carries an affordable M18X1.5 Tap and dye... There is a set, but no way I am paying $110 for something I will never use again... or rarely :nono:
3) The thermostat sold for the 2jzgte and 1jzgte is smaller than the 2jzge, so we had to use the old one once it was cleaned and tested in hot water. No big there.
4) The injectors that came with my 2jzge intake manifold are blue and top feed, but they are not as short and stubby as the 7mgte injectors so those are NOT a direct swap. Wtf? Are the injectors for the SC300 different from the MKIV Supra? It's an SC300 intake, but I figured they all had the same injectors. I can post pictures if anyone knows wtf is with these thin injectors
5) The throttle body touches the turbo, so I am ditching it for an aftermarket one that will cut down 4 inches in length once it is attached to the Y intake pipe... much easier and better than the HUGE stock hunk of junk with a HUGE and USELESS traction control system... Any ideas what should bolt up/weld up?
Things accomplished yesterday:
1) All sensors installed and ready on the motor, minus the knock sensors. Getting those back soon because I am a forgetful retard :sarcasm:
2) Motor mounts and brackets are installed and ready to go
3) Timing is perfect
4) Nice billet pulleys (WP, PS once I get it, and Alternator) are on and looking hot
