Spent the last 9 hours working on my Supra. I removed the stickers from the underside of my hood (still need to take Goo-Gone to it to remove the adhesive), put my wiper arms back on, removed the stickers from my cam gear cover, painted the front rotors where the pads don't touch and rust was building up with caliper paint, replaced my rear cam position sensor connector, relocated a ground wire at the back of my motor to a more hidden spot on the firewall, removed the tubing coming from my camshaft covers, cut off the heat shielding from my hydrofan line, untangled (cut and soldered since they were woven together) the wires going to my fuse box that is currently in my fender well in preparation for relocating it to inside my dash, and removed some excess wiring from my fuse box. I also pulled my dash out. I have a long list of stuff to do. In case ya'll are wondering, I will be taking off my passenger side camshaft cover and putting in an AN fitting for my catch can and will be putting on a small air filter on my ISCV (got the idea from GrimJack's Supra).
