Progressive Power Steering, VAS
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
On the back of the power steering pump there is what seems to be a VAS, is this switch to progress the pump as rpm rise? If it is removed will this leave you with non proggressive steering? or will it be sloppy steering?
this is the back of the pump. the hoel with the plug in it is where the switch was.
This is the switch that came out of the pump.
What that does (it's a hydraulic activated valve) is increase engine idle speed when the car is turned hard at low speed. It prevents an engine stall from the load put on the engine from the P/S pump by opening an air path from the accordion hose to the intake manifold. It has nothing to do with progressive power steering.
grimreaper
2,180
Dallas
its annoying at worst to park sometimes. You can feel the load but a quick blip of the throttle takes care of it.
I would put mine back on (previous owner removed it) if i had a port pre turbo to hook it too.
is that a worm gear on a stainless hose?
SupraMan1987
258
Hickory area, NC
No, it doesn't affect steering feel at all. It idles the engine up when you turn sharp to prevent stalling due to the engine being loaded most likely at low speed by the PS pump.
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
Harford County, Maryland
damn, any ideas on what would affect the tight steering feel at low speed or idle?
