Buddafucco;939758 said:
I read the SF thread. There wasn't much discussed about the cheapo version of proefi which is the one I'm assuming that your talking about here. There was a post about features that were going to be removed to make it cheaper but I didn't see a post that confirmed the actual features for that unit.
Auto trans- End user configurable? (shift points, lock up, etc...)
Batchfire injectors- Is that limited? If I were so inclined, is individual injection possible? Or is it just not end user configurable?
Knock abilities? (I'm not reading through that thread again to find it) A big part of the apeal was the knock capabilities but it was stated the cheaper version wasn't getting the full deal.
Nitrous stage control? 1 stage, 2 stage...?
2 step? Anti-lag? I didn't see anything about this.
I'm in the market for EFI control but I'm probably one of the people that you want to keep it out of my hands. I've got a couple of those frowned upon mentalities. If you want something done right then do it yourself. &. I'm a mechanic, while I may ask for advice occasionally I don't need anyone else to touch my car. There seems to be a secrecy about what the end user will actually have control of. I understand why it's being done this way and that there are certain perameters that I won't need to adjust and I'm fine with that but it would be nice to know what I can do. With no software available I'm assuming the only way I can truly find this out is to wait for someone else to install the proefi, track them down & then ask if they can plug into it so I can get the scoop.
Don't get me wrong. I'm not saying to do things differently on my account. I'm just trying to figure out if proefi is right for me. If I can't buy it and initially tune it myself without the intervention of a "certified" tuner then I don't think it is.
The "cheaper" version I am talking about will be feature the following:
Batch fire peak/hold injection (no sequential available, same as stock 7M)
Direct ignition 6 channels
Wideband input with closed loop control
Inputs for various sensors, such as fuel pressure/oil pressure/oil temp/etc and warning limits/corrective action for them.
Nitrous control
Boost control
Spare outputs for fuel pumps, fans, shift lights, and other items
2 step rev limiter (multiple stages if desired)
Some of the main points the smaller unit cannot do, that the big one can:
Traction control
Sequential injection
Idle control w/OEM stepper motor
Onboard direct control of wideband sensors (no controller required)
Automatic transmission control
Variable valve timing
Drive by wire
More input/output channels
The "secrets" about what the end user will get control of aren't really secrets, they are simply part of a chapter in the book that is still being written. ProEFI and the rest of us all know the concerns over fully locked systems versus systems that are so unlocked it makes your head hurt trying to sort through everything. I am confident a nice balance will be struck, and when the software releases, then I will be happy to go over ever aspect of it to help anyone decide if this is a system that would suit them, or if something else would fit the bill better. I don't sell just one system for that reason, to allow choices within a group of products that I trust to perform as advertised once we make a selection.
My idea with the small ProEFI box was not to bring something out that will knock your socks off with out of this world capability/expandability. I have the M800 for that!
I am just gauging interest in a resonably priced EMS alternative, that performs well most all the functions the average enthusiast needs an EMS to do, in a simple easy to use package.
