I just got my H4 HID Hi/Lo kit in the mail the other day and I am having a problem trying to get the kit to work. I plugged the HID harness into my factory harness and only the halogen hi-beam component worked. I then tried rearranging the pins in the HID harness to see if that was the issue but I could not get both the hi-beams and lo-beams to work. Right now I have the HID lo-beams working but I have no hi-beams.
I was told I might need a relay to get this working properly. Does anyone have a diagram or a link to an install that can help me with my problem? If it helps the 3 pin connector on the HID has a red wire for the igniter on one pin, a red wire for the hi-beam part on another pin and finally 2 black wires for the grounds on the final pin.
Thanks in advance
Steve
Thanks in advance
Steve
