If you have unbolted the transmission from the motor already, you will have to lift the motor first off of the mounts, and then pull it forward from the transmission. BUT, before you can do that , you will have to go through the inspection panels of the tranny to remove the bolts from either the pressure plate, or the torque converter before they will separate.
Once you have it out, it would be wise to go ahead and Drop the driveshaft, and transmission mount, and remove the transmission. It is much easier to re-install the transmission to the motor out of the car. I sit and type this while my transmission sits on a table by itself.
