RockPaperSwoRD;1265262 said:time to swap out to 1jz
CRE;1265318 said:Won't make a lick of difference if his idea of diagnostics is hitting delicate parts with a hammer. :3d_frown:
OP, you get any error codes when you set the jumper to do the timing? You DID jumper TE and E1 when you did the timing, right? Timing is the most likely reason for the hot manifold... you're running WAY retarded. After you get this fixed you should do a compression test... you may have damaged something else while going through all of this.
ciao!
CyFi6;1265362 said:Its supposed to. If you dont want it to shift up stay on the gas
That was my next question, seems a lot of people forget about the jumper wire.CRE;1265318 said:OP, you get any error codes when you set the jumper to do the timing? You DID jumper TE and E1 when you did the timing, right? Timing is the most likely reason for the hot manifold... you're running WAY retarded. After you get this fixed you should do a compression test... you may have damaged something else while going through all of this.
ciao!
AJ'S 88NA;1265672 said:That was my next question, seems a lot of people forget about the jumper wire.
If your timing is retarded that far to fire up the manifold it may not go past 4k, if you keep running it that way you'll have more to worry about then what you have now
CRE, nice to see you![]()
AJ'S 88NA;1265672 said:CRE, nice to see you![]()
