Small hijacking: what is "piston-wall clearance."? Is it difference between piston diameter and bore diameter? Or is it distance between piston and wall on each side?
E.g. piston is 84mm, "piston-wall clearance" is 0.1mm, what bore diameter should be for that? 84.1 or 84.2...
thanks
thanks
