Probe damage, my fault, experts see (Pics)
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
i am starting to figure that melting number 1 piston is timming issue, i dont think it`s beacuse the injectors, they are 6 months old, they are msd and i switched in the past and placed them in different order, probably the other 4 people who melted number 1 cylinder with the map ecu is because we dont have how to control timming.
Any suggestion how can i control timming and keep using the map ecu?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I agree with IJ about the cause of damage
but still.. I wouldn't run a T70 26psi on 100 octane with a full standalone.. much less a stock ECU + piggyback setup. I'd re-think fuel/iginition control when you get it back together.
My car made 677whp on 27psi through a T70, at the level you're at.. you needed a standalone a while ago. You pretty much learned the hard way :(.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
after i melted my piston, i sent the injectors to RC to get inspected and flow tested. the told me #3 was way off. when i got them back and started it up, only 1.5 months later, the same one was off again... i guess their fault. but that just shows their incompetence.
Suprapowaz!(2)
2,870
San Antonio, Tx.
a sess: At least have that one injector tested minimum. If you're going to use all of those injectors again, then you need to have them all tested. I'm sure there's some place in your hometown that tests and flows injectors.
MAP ECU 1 cannot manipulate timing. You just set your base timing to stock specs and cross your fingers... i guess.
What brand injectors are you running?
miked
missouri
Wow. What a carnage!
Can you guys tell me how you know when your injectors are not flowing 100% or is becoming partially blocked while they are still on your car?
Doward
4,245
Alachua, FL
No way to tell - with a really high performance engine, I recommend every 20-30k miles having the injectors flowtested / cleaned.
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
the real question is: What size injectors are you running? The bigger the injector, the more advanced your timing is.
Cool new paper weight though!
