post your ffi's
Dec 3, 2003
6,653
Canada
SupraJDS said:
Where could I get one of these?
Thanks,
Josh
Edit:Sorry for the Hijack
Ron R makes them but is on vacation right now for a while. Best quality out there by far and great flow numbers.
Now back to you folks :)
Duane
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Sorry for the thread jack, but it's relavant.
What are the pro's of using a FFI?
What is needed to do this?
Can you just get new pipes for your intercooler and what not for the new route or is there more to it than that? Tuning?
TobyCat
470
Vancouver BC
Pros: Much better flow in. IC piping doesn't go across the engine soaking up heat. IC piping is shorter - so better throttle response. You can run a good IC with end-to-end tanks.
Cons: Ron isn't making them anymore SO I have to learn welding! =)
You'll need a new IC, and piping to match. You *could* use the same throttle body (correct me if I'm wrong guys?), but I'd do it all in one swoop.
chriso
Supranian
Bay Area, CA
Duane
Is Ron R on personal vacation or just takin' a break from fabbing these things???
chriso
Supranian
Bay Area, CA
Looks like most people are using a 4" pipe as the main piece for the fab. Is this the case? Also where are you guys getting the adapter piece for the throttle body - machine shop???
