About the picture in post #34... What was that person thinking when He put the oil catch can on the valve covers?? :aigo:
jdub said:The best would be an external air pump system, providing a constant 4"-5" of vacuum on the crankcase
I thought about doing that for a while, you should make a new thread showing how you do it.Doward said:FixedMainly because this is the route I'm going.
starscream5000 said:About the picture in post #34... What was that person thinking when He put the oil catch can on the valve covers?? :aigo:
Im planning on moving ONLY the battery, on my frount mount, it would clean up, not keep as much heat under there, and distribute some of my FAT beauty's weight!!!:biglaugh:C.44 said:Isn't it possible to keep the AC AND the battery in front ?
TheNewRed said:Im planning on moving ONLY the battery, on my frount mount, it would clean up, not keep as much heat under there, and distribute some of my FAT beauty's weight!!!:biglaugh:
7Mboost said:But some people like simplicity, and want to be able to go to the track without having to install a cutout switch on the back for your rear-mounted battery. This is the main reason mine will be staying up front.
