Pirate air leak (Arrgggggg)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
The TB should be set up in the following order:
1) Plate just fully closed, stop screw touching stop.
2) TPS adjusted (set IDL contact)
3) Dashpot adjusted. (first check it's functional)
The above is done with the linkage disconnected at the TB. Adjust the linkage and reconnect it last.
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
Harford County, Maryland
Alrighty then.... the throttle stop screw and the dashpot were set incorrectly causing the tb blade to remain open slightly. Idle is reduced to 650rpm when fully warm but now and I have it timed correctly. Something still seems a little off though, idle isnt perfect, rpms move a little and im still only pulling 15inhg. Gotta do some more checking but im getting closer.
