PICS: Greddy vs. Ebay ( SSAUTOCHROME) Manifold!!! And a sneek peak of the TN monsters
crf_rider
88
Portland, OR
IHI-RHC7 said:
Crf, I see you have the big housing on your C7, how does it spool for you?
Numbers?
Full boost (18psi) by 3500 but I am still running the stock cat back. Once boost hits about 10 PSI it basically launches. I am getting a 22cm housing for it also. Your local correct? We should meet up.
IHI-RHC7
"The Boss"
Oregon
Yeah, we're in albany.
I have the 20 cm housing, so I can expect even quicker spool, that's excellent!
We'l have to do a mini nw gathering during dec.
Ckanderson
2,644
The beach
siman said:
I forgot you have on! Is that the one you are using that you coated?
That coating I bought is spray on. My buddy that owns an Airbrush shop will do that for me.....I need to get the manifold sandblasted with 120grit sand and then spray on a thin coat as for say the directions!
just lettin ya know... dr jonez's header never cracked untill he coated it... so yea.. i'd double think doing the header.
crf_rider
88
Portland, OR
Headers need to be coated on the INSIDE as well as the out side. If you just coat the outside heat can not escape and the temp of the metal goes way up. Hence the cracking. Take it to a place that can shoot the full length of the inside.
Figgie: I already had a lot of T3 type headers/adaptors here, but I know exactly what you mean this is why I built an adaptor from T3>T04b instead of cutting and reflangeing the header, so I'm still able to use whatever Turbo I want ;)
quicksilver
56
owensville mo
I don't know exactly what housing i have but It seems like I hit 18 psi by 3300. Its the 4 bolt flange though. Its been a while though so I'll let you know In a month when I put the moter back in.
IHI-RHC7
"The Boss"
Oregon
Man, I really want to get our motor done.
I'm really contemplating just fabbing a dp and putting it on the motor as is, but this supra has been so nice to us, I want to do it right the first time.
That just means such a long wait... :(
siman
Lifetime Ban
Murfreesboro, TN
Already new that!
My friend is going to paint it for me after x-mas.. He is a PROFFESIONAL painter ( airbrush/auto/ house)...I am sure he can dot it just fine :)
Thanks for the heads up thought!
-Jonathan
PS: Dr.J made a mistake....LOL:nono:
MDCmotorsports
Indy 500
www.MDCmotorsports.com
FYI any type of media blasting into aluminum is a no no. The only acceptable media is baking soda. The aluminum is too soft. When you blast it with any type of media, it (the media) becomes lodged into the aluminum and comes out at the most unfortunate times.
Bondango
Supra Specialists Ireland
can i ask a question regarding the turbo and Adapter. Im running the ebay mani with a super t70 turbo which is a hybrid with a divided t3/4 flange. The turbo mani as you know is also divided, but the adapter (which i waiting on arriving) is not divided. Will the make a difference to the spool charateristics of the turbo??
SupraMario
I think it was the google
The Farm
How did i not see this thread. but man kris's car is cleaned out. damn when i saw it last, it was nice, looks weird torn apart.
