bountykilla0118 said:Whats the spool on the jt61's?
Come on man its a bolt on turbo how many different factors would you really need to make a rough estimate. When do most people see full boost with an upgraded ct26? I rarely hear people answer "It depends on your setup". An average would have been good, considering its a bolt on turbo but ok.....MDCmotorsports said:Depends on your setup.....
Intothenight19 said:I like my T04R, relatively quick spool and capable of good horsepower numbers.. Looking to go bigger though soon![]()
djordan97 said:yeah I'd say 18 psi by3500 is very comfortable depending on how you set every thing up.
ToyoHabu said:Holset HX35 with 9 or 12 cm turbine housing, good for 500 HP
wat type of rwhp are you getting if you know?djordan97 said:my set up is the jt61 with 2.5 cooler piping threw a driftmotion spearco replica with a 3inch turbo back and 550 cc injectors and the maft pro in speed density.
supraguy31 said:I had a Mitsubishi Heavy Equipment turbo that I was running on my Supra for a little while. Only problem I found with it was it had a turbine Housing of 17 cm and no one could tell me what it converted it in actual AR Specs.
supraguy31 said:I had a Mitsubishi Heavy Equipment turbo that I was running on my Supra for a little while. Only problem I found with it was it had a turbine Housing of 17 cm and no one could tell me what it converted it in actual AR Specs. I made right at 500hp with it but I hated the Spool time. Set at 8 PSI, I didnt hit full boost until 4200 rpms.
Im stilll looking for a turbo that will hit full boost around 3200-3500 and will Pull its ass off all the way threw redline. Im running a T4 setup and I hear that the 67MM OR 61MM conpressor wheels with a AR.68 or 70 exhaust housing are the best if you are shooting for 500-550wrhp on Pump gas.
Any Ideas ??????
Robert
