Pearl White 91T 2JZ swap and build-up! 56k *lots of pics*
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
I haven't been online in about two weeks due to moving and not having internet until now. I went to the track last week, and untuned, still at 7-8.5psi, ran 13.4 @ 104mph with a crappy 2.21 60ft time (no traction on stock 225's). With a better launch, I'm sure I could see 12's as it sits. I can't imagine what 18-25psi is going to be like! :D
Collin
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
New time: 13.4 @ 105 with even less traction. The difference is I changed my exhaust to an HKS Sport Turbo system and replaced the stock cat with a test pipe. Now hitting 10psi, it's feeling much better. Rolling into boost in 2nd, the car starts to get a little loose. 1st pulls really hard. :D
I also have an updated price breakdown for my swap:
Items purchased: Price:
1991 Supra Turbo (96K miles, beautiful interior, but some body damage) $4,000.00
2JZ-GTE Aristo front clip $2,200.00
Mounts (bracket, solid mounts) $190.00
Rear sump pan $277.00
1JZ Flywheel $223.00
Bellhousing $300.00
Clutch set $278.00
R154 $300.00
7M oil pressure sender $42.00
OP sender relocation line $30.00
MKIV P/S high-pressure hose $264.00
T04R turbo, 4" in, 2.5" out, .81 A/R, 3" v-band $510.00
Ebay SS T4 manifold $170.00
Turbo oil lines $200.00
50mm HKS wastegate $70.00
SSQV BOV $65.00
FMIC $160.00
IC piping $150.00
Intake piping $50.00
Filter $70.00
Full exhaust $500.00
Water pump w/ pulley $130.00
Heater hoses $35.00
Wiring $100.00
radiator, hoses, cooling fans $445.00
1pc driveshaft $300.00
battery, relocation $200.00
Misc. $200.00
Total $11,459.00
Parts to be purchased: Price:
Walbro fuel pump $115.00
Injectors x6 $390.00
Fuel rail, lines $500.00
AEM EMU $1,700.00
Tru-Boost $275.00
UEGO Wideband kit $275.00
AFPR, lines $250.00
Autopower cage 500.00
Seats, harnesses 500.00
Wheels, tires $1,000.00
Coilover suspension (maybe) $1,000.00
ST swaybars $275.00
Paint $1,000.00
Total to be purchased: $7,780.00
Grand total at completion: $19,239.00
There are a few items missing such as my boost gauge, pillar pod, and little stuff that didn't cost a whole lot and that I don't remember. haha. Overall, I think I did pretty good considering. The prices for the parts I have not purchased are guesstimates; actual price may vary.
Collin
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
Collin
i don't understand something collin, on your sig, here and on supra forums says you got a 2.1 60 ft......but you say you pulled a crappy 2.2 60 ft? i know i'ts very little but it definately means a lot out on the track? this is where you want to be very clear on the time and 60 ft you put down
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
2.21 was an old number from my first time at the track with this setup. On the 8th I did 13.4 with a 2.1 60ft.
Collin
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
Collin
Collin
well obviously, that i'm just trying to catch the facts that you went to the track "Last week" and ran a 2.2 60 ft or 2.1?... i don't know where your going with the 2.2 as your old number from the first time you went to the track that was a month or so ago, ............ i'm just trying to get the facts straight thats all collin:3d_frown:
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
There was no attitude in that. I was simply clarifying... The time on Supraforums is more current. The post at the top of this page is older.
